Magic Mary will it ...
[Closed] Magic Mary will it fit?
Looking at getting a magic Mary for the front of my bike for a wet / slippery FOD uplift day.
Firstly, has anyone used one with a rockshox revelation and found it has enough clearance? Wheels/forks are 650b. Rims are fairly narrow so imagine thectyre will have a fairly rounded profile one fitted. Running with inner tubes, not tubeless.
My 2nd question is which version of Mary? Can see a few shops have a cheap 'bike park' version, that's really heavy. I don't think I'd want to drag it round a xc trail but would it be ok for uplift days? Or has it got a really cheap compound of rubber that doesn't grip well?
Posted : 24/03/2017 7:20 am
Good luck if you're going to try & run a SG or bike park MM with a tube, they're a nightmare to fit!
The BP grip well enough, but are steel bead, so are very heavy.
Posted : 24/03/2017 7:24 am
Im not too sure about clearance but I would stay away from using the 'Bike `Park" version on the front. Its a different compound and not very grippy. Ive used the "Super Gravity" version on the front and its easily my favourite tyre.
Posted : 24/03/2017 7:46 am
What tyre do you normally use on the front?
FYI, I ride in FOD quite a lot and Minion/High Roller EXO's cope fine. On the uplifted tracks it doesn't really get that muddy.
Posted : 24/03/2017 8:18 am
I run a Magic Mary on the front of my hardtail with revs (29er,not boost) and it fits fine. Running it on a 27mm internal rim
Posted : 24/03/2017 9:14 am
I've currently got a 2.4" Continental Miubtain Kinf black chilli on there. Fairly new (maybe 5 or 6 rides) and worked great at BPW and pretty well at a wet Cwmcarn. Wouldn't say it's amazing on wet roots though.
I probably run it with too high pressure in fairness but as a result I've never had a pinch puncture. Run it around 35 ish psi (according to the track pump gauge). I've not got a huge amount of finesse as a rider!
It's on a 19mm inner width rim - Mavic X319 I think (whatever is standard on a Boardman Pro Fs).
Posted : 24/03/2017 9:38 am
