Machine shop help -...
[Closed] Machine shop help - custom crown race
Can anyone help recommend a machine shop that could make a custom crown race for me?
Basically I need a hope crown race that is a little taller than normal as the knobs on the top of my fork touch the frame at present. After contacting Hope they do not make them. I think i need approx 3mm additional height on the crown race to clear the frame and would like a custom race that spaces the crown up a little but allows the current sealing arrangement the crown race uses.
I could go down the route of an external lower cup (zerostack headset) but would have to get a reducer crown race for that anyway so would prefer to get a tall 1 1/8 crown race and run extra travel on my fork with little difference in the A-C over an external lower cup.
Any recommendations greatly recieved.
Posted : 17/07/2013 11:21 pm
If you can send a drawing of what you want I can see if I could do it for you..
Posted : 18/07/2013 7:53 am
I'd be looking at my files and the fork tops.
Posted : 18/07/2013 8:04 am
on-one were selling various tall races for a bit after the 'tapered steerer in a 16" c456' issues came out - might be a good start point even if you need to get the angle of the race changed?
Posted : 18/07/2013 8:21 am
I'm sure I've seen thick crown races for sale somewhere before, worth a Google.
Posted : 18/07/2013 9:49 am
could you not just get the hope pick n mix d cup - 1.5 - 1 1/8 step down traditional? Takes a normal 1 1/8 crown race and gives you the extra few mm that you need for the forks.
That's what I run on my yeti.
Posted : 18/07/2013 9:52 am
 P20
King do extended base plates, pricey but effective if it suits your frame
Posted : 18/07/2013 9:57 am
stevied
can do a rough sketch and provide a normal race for measurements etc. The immage i have in my head is if you can immagine a crown race sat on a 3mm headset spacer but made out of a single bit of alu.
DougD
Could do that but would prefer to add 3mm to the crown race rather than 10-15mm in a lower cup so i can run a pair of forks at 130mm rather than 120mm.
P20
Do you know if a king race would fit a Hope headset?
Posted : 18/07/2013 4:50 pm
 P20
Doubt it. I meant change to complete king
Posted : 19/07/2013 9:33 am
