After a year of use my M980 XTR pedals have a small amount of play in the axle. Can I just take the axle out, clean, regrease and reassemble? or is there a part to replace whilst I'm in there?
Posted : 11/07/2012 3:47 pm
Take the body off the axle and you can adjust the bearing to take out any play.
Posted : 11/07/2012 5:34 pm
Should be straight forward.
You need 2 small spanners, 10mm and 7mm for most Shimanos.
Fill with grease and refit...they should last for years.
The first service/rattle is usually after about a year, then it will settle down and be years before needing doing again.
Not like Crank Bros.
PaulD
Posted : 11/07/2012 6:12 pm
Just watch out for the collar seal which will push out when you purge with grease. A fine screw driver will allow you to push it back in.
Posted : 11/07/2012 6:41 pm
awesome, cheers guys.
Posted : 13/07/2012 11:49 am
