Lyrik riders - what...
[Closed] Lyrik riders - what are your settings?
Weight:
Spring:
Rebound:
High Speed compression:
Low speed compression:
Rebound:
Posted : 14/07/2011 11:26 am
older lyrik or new DH?
Posted : 14/07/2011 11:29 am
older with DH mod here (floodgate removed)
Posted : 14/07/2011 11:31 am
73kg nekkid
med spring
lots of rebound
LSC 4 clicks
HSC 0 clicks
no DH mod, but doesn't feel very plush. Would like to try a soft spring
Posted : 14/07/2011 11:33 am
Doesn't it depend on what type of terrain you're negotiating? Regular large drop-off vs canal tow path?
Posted : 14/07/2011 12:01 pm
98kg
firm spring
4 LSC
0 HSC
Lots of rebound
2011 Lyrik DH
Suspect it's still breaking in (or was before I had to send it back under warranty) - so settings may well change + I suspect they'll change anyways as the seasons change.
Posted : 14/07/2011 12:08 pm
Year: 2007
Weight: 90kg's
Spring: Medium
Rebound: 4 Clicks from off
High Speed compression: 4 Clicks
Low speed compression: 2 Clicks
These settings I use for most of my riding.
Mods: - I have the Floodgate mod,
The Boxxer mod (Replaces the internal wiper for sponge rings)
and I removed the U-Turn system which gives me non adjustable 170mm travel instead of 160.
The Boxxer mod makes a massive difference but you need to increase the service intervals.
Posted : 14/07/2011 12:15 pm
 Ewan
KonaStoner - are there instructions on the web for removing he uturn system?
Posted : 14/07/2011 12:19 pm
Weight: 12 and half stone in the buff
Spring: standard Medium
Rebound: err, some clicks
Low speed compression: 3
Floodgate: 1
This is on a coil u-turn set with Mission Control. Lovely, lovely forks.
By the way, have you seen this yet?
Posted : 14/07/2011 12:30 pm
Weight: mid to high 80s
Spring: medium
Rebound: the right amount
High Speed compression: none
Low speed compression: quite a bit
Used to have a firm spring but it was too harsh in the Alps. Medium spring is a little soft for me hence the lots of LSCD to stop it diving on me.
As forks go its great but it REALLY needs an internal clean and oil change quite regularly (every few months for me) to stay at its sooper smmoove bestest. Luckily its a 30 minute job on RS forks.
Posted : 14/07/2011 12:32 pm
 Si
Interesting Ta Rik
Posted : 14/07/2011 12:33 pm
Not that i'm aware of it was a mod I done myself. I can do some instructions if your interested.
82kg
Firm Spring
4 + High
4+ low
DH damper - aftermarket fitting
Posted : 14/07/2011 12:35 pm
bump
Posted : 15/07/2011 6:54 am
 jedi
14stone
firm spring
full hc
3 clicks low
Posted : 15/07/2011 6:55 am
Weight: 15st
Spring: Med
To be honest I have no idea on the settings, I got them just right and left them. I have done the floodgate removal mod, I do think it makes a difference- mine are the old ones with less oil in.
Posted : 15/07/2011 7:17 am
Weight: 83kg
Spring: Med
4+ High
4+ Low
Quite a lot of rebound.
I do tend to muck about with the settings a lot to experiment, switching off HSC made the fork bottom out with a loud thunk on a rocky descent.
Posted : 15/07/2011 7:39 am
2010 Lyrik DH with U turn mod
56kg
X soft spring
Rebound - about half way
HS - 0
LS - 5
Posted : 15/07/2011 7:57 am
(MR MC posting)
Have you seen the MiCo guide
SRAM.COM "http://www.sram.com/_media/pdf/tuning_guides/missioncontrol_tuningguide_en.pdf"
/p>
+4HS
+4LS
1 turn floodgate
+12 rebound
recommended starting point for 160-180lb riders (I'm prob 160 with a full camelback). Pretty close to my Lyrik Solo Air settings, though Ive also done the DH mod (ditched the floodgate).
Link to floodgate mod guide
http://mikelevy.pinkbike.com/blog/tech-tues-lyric-mod.html
Posted : 15/07/2011 8:12 am
Posted : 16/07/2011 4:55 pm
nowt showing dude
Posted : 16/07/2011 5:18 pm
