Luftkappe & 201...
[Closed] Luftkappe & 2019 Debonair Shaft Together?
I need to buy a new air shaft to change my 130mm Pikes to 140mm (650b).ย  I already have the Luftkappe installed, can the Luftkappe be installed onto a new 2019 Debonair air shaft?
If yes, does it give any benefits over the older RS air shaft with Luftkappe?ย  I see the seal head has been improved, but I am unsure if the 2 systems will try and do the same job with the negative air and not work well together, or just create too much negative air.
Posted : 10/06/2018 2:02 pm
Incompatible as the 2019 debonair shaft has the piston riveted onto it.
Posted : 10/06/2018 3:57 pm
Ah that answers my question then.ย  I will just get the old air shaft and move the Luftkappe over.
Posted : 10/06/2018 4:46 pm
