Lower back pain
[Closed] Lower back pain
This has now happened twice. First at the Dyfi Enduro and yesterday at Llandegla. Both times I was cycling hard uphill and obviously putting strain on my lower back. A new saddle on the Cotic seems to have cured it but I was on the Specialized Enduro yesterday so probs again.
Anyhow - has anyone got any tips about excercises or stretches I could do to help? I heard that stomach excercises are good, is this right?
TS
Posted : 08/06/2009 4:56 pm
hey, i know the feeling, i have has a back pain prob for a few years, after phsyio to corect my allignment, i started pilates classes. which strengthens your core muscles to hold your whole frame. this is a slow process but im now getting the rewards, i also do a one to one class on pilates equipment, over last four months which has brought my recovery on a lot more. plus you enjoy the added bonus of a flat six(ish) pack tum
Posted : 08/06/2009 5:12 pm
I've got that new camelbak mule with the nv backing to make it more comfortable. Whenever I fill the bladder up, I get pain in my back, and that doesnt go away until I've drank about a litre or so. Apart from that, its a great camelbak.
So you could just try getting saddle bags or something, changing the position of your camelbak, and removing as much weight as possible.
Posted : 08/06/2009 5:19 pm
definitely look to improve your core muscles. i get sore backs, but in the last 18months i've paddle surfed and that drastically works out your core muscles. touch wood, but i now can't remember the last time my back locked up.
Posted : 08/06/2009 5:26 pm
Another vote for pilates. However its an ongoing routine - we should all do exercise to strengthen our core to help our backs as wear and tear takes its toll - that's without all the riding we do.
It will not be a one off incident more than likely - its to do with poor posture and overuse of certain muscles over a period of time.
Core stability / strength work. Look at your riding position - I find higher bars help greatly. Ditch the camelback - your back is already in a bad shape on the bike and weight acting on it will not help.
Pilates / gym work / alexander technique all can help
Posted : 08/06/2009 5:31 pm
Hamstrings .... plenty of riding will shorten them,so make a habit if stretching every day and especially before a ride.
Posted : 08/06/2009 6:04 pm
Cheers guys - sound advice. Never thought about the camelbak!
I'll check out Pilates as well
Thanks
TS
Posted : 08/06/2009 6:07 pm
 jedi
for me its usually a tight psoas muscle .if you lay on your back and press beside your hip into your stomach and lift a leg you can feel it.i press massge this and its all good
Posted : 08/06/2009 6:15 pm
the pain is often a manifestation of a problem / problems elsewhere that may not be obvious - so specialist advice is essential, the following worked for me; stretching every day - its not as hard to get into the routine as you might think and is actually quite relaxing(the anatomy of stretching - Brad Walker, will help identify a routine), sort bike position out (lots of advice on internet) and finally Chiroprator (not sure if it is this discipline, or just that i have found a good guy).
Good luck.
Posted : 08/06/2009 7:43 pm
