Low stack height st...
[Closed] Low stack height stems - what's out there...
Thanks in advance
Posted : 10/06/2013 12:00 pm
Sunline V1
Ragley Stubbing
both about 30mm I think
Posted : 10/06/2013 12:03 pm
My Easton haven stem has a pretty low stack height. From experience the nicely machined (think Hope, Easton and Thompson)ones have lower stack height.
Easton Haven is really nice, I can measure stack if you like?
Jamie
Posted : 10/06/2013 12:06 pm
Thomson/Hope etc are all about 40mm
the On-One superlight/Sunline/Superstar CNC jobby is about 35mm, and there a few 30mm ones out there, think Funn do a couple of really low stack height stems but are a bit DH'y...
Posted : 10/06/2013 12:08 pm
Please Jamie
Not many list the stack height in their details.
Posted : 10/06/2013 12:10 pm
Amedias is right, my Easton is 39mm face to face... so not as short as I thought... Hope XC measures up about the same.
You're right not many people list the stack height, I had the same problem when using forks form an internal headset frame in a frame with a longer head tube and external cups... steerer was just that bit too short. Got aoround it in the end but every mm of stack height became critical!
Posted : 10/06/2013 12:44 pm
Spank Spike - ultra low stack height.
Might have to source one second hand though.
Posted : 10/06/2013 12:46 pm
 qtip
My Straitline stem has a pretty low stack height, certainly quite a bit lower than the Hope I used to have on there.
Posted : 10/06/2013 12:50 pm
asked this question myself just before Christmas last year..., like Ecky-Thump said you want a Ragley Stubbing or a Sunline V1. Went for a Stubbing myself (30mm stack)
Posted : 10/06/2013 1:06 pm
Turbine is 39mm too for the record... Not much help other than for elimination.
Posted : 10/06/2013 1:40 pm
Old style Spank Spike is 26mm I believe, with a 35mm reach and quite a lot of rise.
[url= http://ride.io/news/9th-day-of-christmas-comp/ ]SPANK SPIKE[/url]
I have a BNIB one in the shed I bought when I thought my new fork steerer might be a little short ๐Ÿ˜ฅ
Posted : 10/06/2013 2:08 pm
If you're not worried by single bolt clamp then this might be the ticket:
I have one on my rigid ss and there's only 3mm of tube sticking above the top edge of the bolt...and it never missed the beat!
Posted : 10/06/2013 3:21 pm
FSA OS-150 stems (not all models, mind) are short - somewhere between 30 and 35mm IIRC.
My swift up above has a long head tube and a slightly short steerer so I have the short OS-150 stem and a very short stack headset (Crank Bros directset) which is only 19mm stack height, saving 20+mm over most other headsets. That said, they're 1 1/8" only and some people say they're rubbish though the two I have are holding up well other than some surface rust (cosmetic, on the outside only).
Posted : 10/06/2013 3:25 pm
