Low friction seals ...
[Closed] Low friction seals on Fox float 36:Much difference?
I have used the Racing Bros low friction seals on u-turn lyriks and they make a real difference to small bump sensitivity, but you are replacing a rubber seal with a foam ring. Has anyone used the low friction seals on a fox 36? Does it make any difference as they already use a foam ring.
Posted : 22/10/2013 8:32 am
It makes a small difference, its worth swapping to them the next time you need new seals, but probably not worth doing unless you need new seals anyway
Posted : 22/10/2013 8:56 am
Thanks for that.
Posted : 22/10/2013 9:58 am
