Looks like it might be scary buscuits.
Flint+roots+chalk+rain= whack whack oops.
The concentration needed for it will be as draining as the flippin hills.. Glad I am going to Beastway instead!!!
its not that rooty, and the chalk/flints are no different as the chalk tends to be broken rather than ice smooth
not quite as quick as in the dry, but yeah watch for the odd slide on the corners
edit: get yourself up to aston for a lap tonight, that will set you up properly
One of the races last year was wet iirc, made things rather interesting. Planning on being out there unless it is pissing down.
Not rooty!
what are all those woody bits sticking out of the ground under the trees then?
It's going to be dry all day then hoon down at the start. ๐
[i]its not that rooty, and the chalk/flints are no different as the chalk tends to be broken rather than ice smooth
[/i]
Yeah, right... just going to put a Mud X on the front, and drop the psi on both.
I reckon if it rains as threatens, lights are also a sensible precaution.
personally i dont struggle with the roots there, perhaps i dont go fast enough.
now that there is full tree cover, if a big set of dark clouds rolls in, as it did yesterday lunchtime, you could use lights a lot earlier than expected.
have fun all.
I've only got Racing Ralphs at the mo.
Told ya.
I am just so rubbish in the wet, ace in proper mud but not slippery hardpack. ๐
More than 10% of the field punctured by running low pressures to get that all essential grip, I was one of them. And don't say tubeless as they were amongst the 10% that suffered.
Biblical rain before the start?
No just a nice damp coating on otherwise hardpack, like Diesel on tarmac ๐
Edit. It's perfectly ok to ride over, but hard at race pace.
i know a story about a hare and a tortoise.
i did wonder which of the very localised showers would get you, woods were greasy as hell at 1700 when i was running.
hope you had fun anyway - im out for a social ride tonight, losing control of the back end is whats its all about.
Low pressure Nobby Nic up front helped, along with a 'sliding' Larsen on the back. Luckily the rain held off, and it was lighter than I imagined.
I nearly stopped after just one lap, I was just not having fun - but seeing the 'oldgit' stood there, having given-up, meant that I just had to continue - and once I'd done the 2nd, the 3rd just had to be completed.
It was interesting to watch ๐ฅ
Lap times were right down. I think I'll buy one of those get you home air/sealant cans for the next one and plod round if I puncture again. Hats off to those that raced it, I was cream crackered just trying to keep upright.
