I've just tried to fit a new gravity dropper.
My old Kona Coiler frame takes a 30mm seatpost. A 30mm post fits perfectly. You have to wiggle it around a little to move it up and down, but no force is required.
I got a 27.2mm gravity dropper and a 27.2mm - 30mm shim. I thought that combination would be right, but it's loose. If I release the clamp it instantly falls straight down. When tight, the seat post doesn't make contact with the entire circumfernce of the shim.
Have I got a dodgy shim, or is that normal when using a shim? The shim is not a gravity dropper branded shim. Is there something different about the gravity dropper ones? They didn't have any in stock when I placed the order.
If I use the seat post like this, do I risk damaging something?
what does your gut instinct say?
You really need a close a fit between the seat post and frame or damage will happen quickly.
Yeah, you're right. I didn't really need to ask the question! I'm hoping to take this to the Alps on Friday, so hopefully I can find another shim quickly.
