The inner axle on my Hope front hub is loose, making it a bit of a faff fitting the front wheel.
I can’t work out how it should be held in place and how to refit … I’m trying to avoid removing the bearings if I can help it.
Posted : 03/08/2024 7:54 pm
Can you line it up and press the bearings a little?
I think it should be a relatively tight fit on the bearing inner section, but not 100% sure.
Posted : 03/08/2024 8:02 pm
