After 1500KM of pretty tough going in the Dales my Fox 32's on my Canyon Nerve 29er have gone kaput (worn stanchions and bushes).
Can anyone recommend any 120mm forks for less than £350. I don't mind second hand as long as they are in good condition.
Thanks
Rockshox Reba RL. Good, cheap, and easy to service. (You probably want to do this more if you've trashed a set of bushes and stanchions!)
If you can get away with a green fork and need tapered then bike-discount have some very cool green ones with black stanchions for £230.
Have a look at Alltricks. There are some great deals to be had
I have serviced the forks as Fox prescribed (well almost) and have done 4 lower leg services. Never mind.
Cheers though, although the lime green won't go well with my stealh colour way they have some Reba's for £279 so will double check prognosis on old forks with LBS and then pull the trigger!
X-Fusion Trace would be a good option
Thanks Tracey,
Just ordered some REBA RL Solo Air with push loc from Alltricks for £300 delivered!
