Looking for a part ...
[Closed] Looking for a part - but no idea what it's called.
[#6655889]
I've seen on some road bikes a second Seatclamp that goes round the seat post to allow you to put the Seatpost back in at exactly the same height.
I want a 27.2mm one but have no idea what to search for. Anyone have an idea?
Thank you.
Posted : 23/11/2014 10:10 pm
Electrical tape - universal fitting 😛
Posted : 23/11/2014 10:12 pm
Permanent marker line. It's the ultra lightweight option.
Posted : 23/11/2014 10:13 pm
Thanks but not what I'm after.
Posted : 23/11/2014 10:14 pm
You could use a clamp slightly larger than you need with a rubber shim. Or just use your rear light clamp to do it.
Rockshox do the blingy enduro collar but not sure what size it is machined for.
Could use one of these little things http://www.xcracer.com/shop/viewproduct.php?productid=351
Or alternatively (if you had a larger seatpost this would be perfect), one of these with a small shim. The clamps have no lip, so they can be used for exactly the purpose you described. And they weigh bugger all so you don't have to worry about weight gain.
http://www.xcracer.com/shop/viewproduct.php?productid=259
Posted : 23/11/2014 10:24 pm
Aah. That might do it. I take my seatpost out when I wash my bike and I want something to get it back in the right place. I've tried tape but it just comes off. Thanks
hite-rite?
Posted : 23/11/2014 10:25 pm
Jubilee clip
Posted : 24/11/2014 1:27 am
Jiggle pin?
Posted : 24/11/2014 1:53 am
Cock ring?
Posted : 24/11/2014 2:01 am
wysiwyg - Member
Cock ring?
Aye, but its for a 27.2mm post. Are rings available that small?
Posted : 24/11/2014 7:17 am
cable tie ?
Posted : 24/11/2014 7:59 am
self tapping screw?
Posted : 24/11/2014 8:43 am
Why?
Posted : 24/11/2014 10:02 am
Posted : 24/11/2014 10:07 am
 iolo
Drill a hole through your frame at the bottom of the seatpost.
Put a bolt in, nut on other side.
Bingo, your seatpost always stops at the correct height,
Posted : 24/11/2014 10:13 am
that's got to win the prize for the most extreme solution to to the most tiny of problems.....if it can even be classed as a problem at all
Posted : 24/11/2014 10:23 am
[i] I take my seatpost out when I wash my bike[/i]
Why? +1
Posted : 24/11/2014 10:24 am
Why indeed? But if you must, why not scratch a small line in the post, works for me on the one & only bike I let others ride!
Posted : 24/11/2014 10:27 am
Electrical Tape
Posted : 24/11/2014 11:27 am
You need a double locking sprocket or alternatively a humidensifier plate...either of these will work
Posted : 24/11/2014 11:34 am
Nail varnish
Posted : 24/11/2014 11:36 am
A 6"4' I tend to find most posts ready marked at the height I require.
Posted : 25/11/2014 12:23 am
If someone did this product but so that the saddle remained straight...
Posted : 25/11/2014 12:55 am
Take a broom-handle and use that as a spacer between the bottom of your seatpost and the bottom bracket. Obviously it'll have to be a similar diameter to your seatpost otherwise it'll either not fit in the frame or could potentially slide inside your seatpost when refitting.
This is a delightfully elegant solution as it is not visible from the outside, so no additional clamps required 🙂
Cheers, Rich
Posted : 25/11/2014 9:44 am
 JoB
bikeneil - Member
where have you seen this?
like many others i use electrical tape, i wash my bike (with the seatpost in), it's never come off
Posted : 25/11/2014 9:49 am
