Well, new patrol, not that different! More to come
https://www.pinkbike.com/u/TransitionBikeCompany/blog/transitions-new-oncoil-patrol.html
Same frame, coil shock as standard, two new colours. Looks sick 🤟
Was thinking of getting a coil for mine, but the price would be ridiculous, to be fair i've probably not even set up the DPX2 properly to get the most of out it!
Just put a coil on my Patrol and two rides in - it is amazing. Deals better with square edged hits, greater consistency in action, more efficient pedalling and rides higher in the travel. The previous Kirk shock was good - the TTX is brilliant.
Will still hunt around for a coil 205x65, but not too bothered about finding one just now, quite happy with the way it rides at present, as i'm not exactly using it to the full potential anyway!
Agree the new Bomber CR is pretty good if you don't mind not having a climb switch and just want something plush for rough days -
Agree the new Bomber CR is pretty good if you don’t not having a climb switch and just want something plush for rough days –
Just spent the weekend at Coed y Brenin. Not needed to touch the compression settings once. If the coil shock is setup properly - I don’t think you need one.
I've a CCDB coil on my rocket without the climb switch. Never felt like I needed it. Certainly doesn't wallow all over the place and it's not difficult to climb.
aren't these going to bottom out at the slightest hint of rowdy?
Will they supply the correct spring rate for each rider?
might mullet maybe
like the completes, would change much
ust spent the weekend at Coed y Brenin. Not needed to touch the compression settings once. If the coil shock is setup properly – I don’t think you need one.
TF Tuned can also Push tune the Bomber.
