Little tips and tri...
[Closed] Little tips and tricks when building a bike, cable tidiers etc.
Like the washer over the zip tie trick or peterpoddys cable tidy tip
Any top tips out there?
Posted : 02/09/2012 8:31 pm
Fit cable oilers at the outset.
Posted : 02/09/2012 8:34 pm
You menton some fantastic tips, but don't explain them.... ๐Ÿ˜ฅ
Posted : 02/09/2012 9:01 pm
The pic is peters rubber tube and zip tie to keep cables off the paint tip. Slide rubber tube 10mm over cable and over a zip tie and then use that wherever to keep cable off the frame.
The washer tip i cant find a pic of, same theory but use on vertical plane. Bend zip tie in half, push washer over the crease, put cable through the loop youve created. Attach tie to whatever.
Posted : 02/09/2012 9:19 pm
I like that one pictured, nice one!
Posted : 02/09/2012 9:21 pm
