Liteville 301 Mk10 ...
[Closed] Liteville 301 Mk10 help.
Can anyone with a medium LV 301 tell me the total headtube stack, over the top and bottom bearings please?
I'm trying to work out the minimum steerer length that I can get away with - I know what spacers and stem I'll be using and know the headtube is 130mm but I'm 2000 miles away from the bike and so I can't just go and check.......
Thanks guys!
Posted : 05/07/2017 12:10 pm
I can check tonight.
the top and bottom bearings are internal to the headtube though so it wont be that much different i would have thought.
Posted : 05/07/2017 12:11 pm
As Andy says, the Syntace headset has minimum stack. I can also check tonight..
Posted : 05/07/2017 12:19 pm
Thank you both - I'm much obliged. I'm just checking to see whether the forks that I'm interested in getting are going to be too short or not. Knowing my luck........
Posted : 05/07/2017 1:22 pm
what length is it? 185mm rings a bell for mine
Posted : 05/07/2017 2:02 pm
Apparently 215mm, then I'll want 25mm of spacers and a Renthal Duo stem.
Posted : 05/07/2017 2:24 pm
ive got about 185-190 i think and run a duo with 3 spacers.
Posted : 05/07/2017 2:34 pm
Thanks for that, Andy - I reckon that I'll risk it......
Posted : 05/07/2017 3:10 pm
dont go on my sayso till ive checked ๐Ÿ™‚
Posted : 05/07/2017 3:15 pm
Okey-doke!
Posted : 05/07/2017 3:20 pm
Yup 130 and 185 steerer
Posted : 05/07/2017 7:02 pm
Thank you very much, Andy. Exactly what I needed to know!
Posted : 05/07/2017 8:46 pm
