I currently have a Charge something or other Tange Prestige frame and forks that is set up SS for the above duties.
It was meant as a SS/Alfine bike and does not have a derailier hanger nor do the dropouts lend themselves to a bolt on version soooooooooo
Looking for a new frame.
Not looking to spend a huge amount as it will be used for the above but would need a 68mm BB and ideally QR dropouts but by no means a deal breaker. Clearance for something more than 32mm 700c tyres would be preferable.
Any suggestions?
I should add a flat bar set up would be preferable.
Cotic Roadrat?
Another Charge cooker (I presume that's what it was from the description) but the geared version?
Similar but different, On-One Inbred? Bonus they came with pannier and mudguard mounts
Cinelli Tutto Plus?
They sell as a flatbar single speed build or a frameset and it can also work with drops and has a mech hanger as well as horizontal QR dropouts so it's pretty versatile for building most things! Clearance is somewhere in the mid-40's on a 700c wheel, plus 68mm BB.
Not sure if it works for your budget but may find something cheap second hand/frameset only?
Oh and they look cool!
Scout out whatever the local recykabike organisation has in.
