light bicycle carbo...
[Closed] light bicycle carbon rims
Vivian at LB is telling me:
If you like hubs in 32H, you can choose DT Swiss 240S J-bend 6-bolt. Or straight pull center lock/ 6-bolt hubs in 28H are available.
What to do? Will the 32h be considerably heavier?
Posted : 21/08/2015 8:37 am
32 will not be considerably heavier, but I would have thought - considerably stronger!
Posted : 21/08/2015 8:47 am
I have the 35mm rims on DT Swiss 240 28h straight pull. They are plenty strong enough. I can get away with 18psi tubeless and haven't managed to ding the rims despite repeated attempts.
Posted : 21/08/2015 8:56 am
So for my Kinesis Sync how does this sound?
-Rims: 38mm width, UD matte
-Hubs: Black, DT Swiss 240S J pull 6-bolt 15mm/12*142mm for Sram xx1 (32H).
-Spokes: Black, Pillar Aero X-TRA 1420 aero
Any suggested changes?
Posted : 21/08/2015 9:37 am
R mac. How have you found those hubs? Do you have any worries that they aren't genuine?
Posted : 21/08/2015 9:50 am
Sorry enmac. iPhone typo...
Posted : 21/08/2015 9:54 am
I have similarish but Hope hubs. Only suggestion I'd make is I asked for a couple of spare spokes and nipples in each length used.
Posted : 21/08/2015 9:55 am
HaydPD - Member
I'd have the 32s. Not so much to do with the 20 grams weight difference, more to do with them offering them with j-bend spokes. After fun times trying to find replacements for mine in the past, I'll try and never own a straight pull wheel again.
Posted : 21/08/2015 10:49 am
[quote=bigjim ]some DH teams using carbon rims have been experimenting with very slack builds to get around this.
<sigh> apart from rim stiffness making a negligible difference to comfort when you've got 60-70mm of travel in the tyre attached to it, spoke tension makes no difference to wheel stiffness unless you have so little that spokes are going totally slack - at which point you lose most of the advantages of a pre-tensioned wheel and it becomes a lot weaker, which is about the last thing I'd have thought DH riders would want.
Posted : 21/08/2015 11:15 am
My hubs didn't come from that ebay seller, I got the front and the spokes from Bike24.de and rear from a set of Roval Traversee's which is essentially a DT Swiss 240. I bought several direct pull spare spokes so I have no worries about getting spares.
Posted : 21/08/2015 4:02 pm
anyone using Farsports rims?
specifically the 30mm wide x 30mm tall - just prefer the aesthetics of the deeper rim
Posted : 29/08/2015 9:05 pm
Just an update on my LB wheelbuilds. I've now used them for a couple of months, trips to Mid Wales, Antur, Slovenia (which is the rockiest place I have ever been) and last round of UKGE. The wheels have passed with flying colours. Not even had to tighten a spoke. They have been scratched a few times, but true as when I built them.
However, I cant say that I notice that much difference. The stiffness is slightly noticeable, and the tyres do look fat on them - I often get comments on what size tyre I'm using.
Now the idea was to use my old wheels as my winter wheels/tyres.. I'm not sure I want to! Although could be a good comparison to feel what they are like again.
Posted : 25/09/2015 11:36 am
I'm thinking of getting the 38mm 650b rims as on paper they have the same ERD as 26" flows, and since I have some rather expensive i9 torch hubs and aluminum straight pull Spokes it would be handy to be able to re use them.
Anyone done similar or forsee any issues?
Posted : 26/09/2015 3:29 pm
 akak
The issue would be that the LB quited erd isn't right as mentioned a lot in this thread and the spokes will be too short. Presumably would cost you nothing to try it though before ordering spokes.
Posted : 26/09/2015 4:11 pm
Except the i9 spokes are ludicrously expensive, so you sort of want to get it right or not at all. Rather than "I'll try this, and if not I'll just chuck these spokes away and order some more".
I had exactly the same dilemma with some road rims, couldn't guarantee the ERD was gonna work and couldn't be arsed to try finding straight pull spokes when it wasn't!
Posted : 26/09/2015 4:17 pm
Yeah. £4 a spoke for a full build is pants down town! I have 1-2mm per spoke to play with based on threads showing in the hubs, I love the hubs and Spokes so may give it a go, worst case I rebuild onto the flows and sell, funds go towards new hubs or wheels, do have a set of 240s I could use instead if the i9s don't work out
Posted : 26/09/2015 5:56 pm
I have a similar dilemma. Have some Hope Hoops in 26" ZTR Crest flavour with an ERD of 540mm and wondering whether a 650b LB 38mm rim with quoted ERD of 535mm will be a straight swap. LB appear to measure ERD in such a way that what I'm suggesting isn't quite as stupid as it would appear if you take the numbers at face value. On the plus side if I'm wrong the straight pull spokes I need won't be quite so ridiculously expensive.
Posted : 26/09/2015 6:13 pm
I was packing my bike up last night to go to the Alps on Friday and noticed this crack in my LB rear rim 🙁
Have emailed LB with pics. Waiting to hear back. The rim was new in May.
Posted : 14/10/2015 10:58 am
I have now managed to crack both of my 35mm wide LB rims. The original 30mm wide ones are still intact.
I currently have a pair of 35mm ones to be built up for a 27.5+ project, I am going to go head with this as I think 3'' of rubber should be a good buffer.
The question is do I go with another set in 38mm flavour....
For what it is worth I have seen many busted Enve rims too, including 70s.
Posted : 14/10/2015 12:21 pm
When I had my 38mm rims built onto my hope hubs, the lbs stated they were using 26" spokes.
Posted : 14/10/2015 1:47 pm
Eh? You don't get 26" spokes, you get spokes in different lengths, but not wheelsize specific.
Posted : 14/10/2015 2:23 pm
I think he means the 38mm rims are so deep the spoke lengths are what you would more usually use to build a 26" wheel.
Posted : 14/10/2015 2:28 pm
...or he's got 52" wheels?
Posted : 14/10/2015 2:30 pm
not Light Bicycle carbon wheels, but could one of you guys check these out. i'm thinking about treating myself for xmas.
[url= http://www.ebay.co.uk/itm/27-5inch-MTB-AM-DH-carbon-bike-wheels-35mm-wide-x25-5mm-Tubuless-Thru-Axle-hub-/261975444382 ]ebay linky[/url]
good feedback on ebay so not worried from that point but are they comparable with Light Bicycle wheelsets. anyone actually got some?
Posted : 14/10/2015 9:05 pm
Yes, I've got 52" wheels. That clears it up nicely.
Or, the spokes for the wheels on my build were what the lbs would 'normally' associate with a 26" wheel build. Please excuse me for not knowing the exact length that was used.
Although its quite therapeutic lacing a wheel, its something I'd rather just pay for to be done correctly and efficiently.
Thanks rubber buc.
Posted : 14/10/2015 10:21 pm
Are you saying that's a good thing then? Bit confused. As spokes come in 1mm increments there's not really a point where you transition from one to t'other. But anywho.
Built up my FarSports road rims last week, built up really nicely, very well finished. Interestingly they have the drive side marked, but spoke holes aren't offset or owt, unless they're reinforced and reliant on you not crossing the valve hole to get it right.
Posted : 15/10/2015 9:42 am
If you read the comments further up, there are a couple of people with 26" wheels with nice hub/spoke combinations that are wondering if they could potentially relace them to the lb 38mm rims. I'll try and get the spoke length that was used for mine and update the post.
Posted : 15/10/2015 9:56 am
Update on my cracked LB rim (photo above):
Just back from 3 days riding in Chamonix - the crack has grown a bit but the rim has not failed yet.
LB are sending me a replacement rim on warranty - I'm paying the £30 postage costs.
Posted : 21/10/2015 11:37 am
 Ells
Anybody got any pointers on which tubeless rim strips to use in the 38mm wide 29" rims?
Posted : 27/10/2015 5:05 pm
I just used gorilla tape. Has lasted for a year with no leaks.
Posted : 27/10/2015 5:08 pm
I just used a couple of wraps of stans yellow tape to cover the spoke holes on my 65mm rims. They've been fine and the rim bed is a good profile for running tubeless so the tape doesn't need to go right to the bead.
Posted : 27/10/2015 5:09 pm
 DT78
Good to hear about the warranty support, mine are still going strong and I'm thinking about a second set. I've used gorilla tape for tubeless to without any problems.
Posted : 27/10/2015 6:29 pm
Ells - Member
Don't stress too much about it- basically once the rim gets wide, you can just use much narrower tape than the rim. It's only really an issue on a narrow rim. Reason being, if the tape doesn't reach the sides but does come out of the well, the tyre'll push it off when you change tyres. But if it's all down in the well, it's safe.
I used roval blue tape in mine, because I have loads of it. Gorilla tape seems just as good.
Posted : 27/10/2015 7:37 pm
Gorilla tape is good Until you have to remove it...
Posted : 27/10/2015 7:52 pm
 Ells
Thanks for the info on the tubeless... are you just using the 1" wide gorilla tape?
Posted : 27/10/2015 7:58 pm
 MSP
Anyone got experience of the blue schwalbe rim tape, seems thin and light which would suit me.. Currently using standard velox tape which seems quite chunky and my tyres are a tight fit so it gets pushed about if I'm not careful when changing tyres..
Posted : 27/10/2015 8:44 pm
I use one wrap of the wtb yellow 30mm tape on my 38mm rims, just stuck a new wtb vigilante on there and can't wait to get out and ride on them
Posted : 27/10/2015 9:29 pm
mattyfez - Member
Even if you're not doing tubeless, use tubeless tape- it's lighter than any oldschool rim tape. Only really makes any practical difference if you need to replace a spoke
Posted : 27/10/2015 11:13 pm
I'm running folding schwalbe ron/ralph 2.1 26er they are an arse to put on if new tyres, that's with a 27mm internal width.
They loosen up though once stretched on lol! But you will say swear words if the tyres are new.
Posted : 27/10/2015 11:25 pm
 DT78
I can gorilla tape might be a pain to remove but can't imagine why you would want to? Mine have been perfect for 18months now (been through about 5 tyres)
Posted : 27/10/2015 11:53 pm
DT78 - Member
Bust a spoke, need to get to a spoke hole. Though, if you're a bodger you can just remove a small area to get to that spoke then patch it.
Posted : 28/10/2015 12:19 am
Does anyone know whether the 38mm rims would fit in the back of a Spec Enduro 2015 29er frame?
Posted : 01/11/2015 11:21 am
The rim will, it'll depend more on the tyre. If you're on the limit with a 25mm rim that same tyre may well not fit.
Posted : 01/11/2015 11:37 am
 MSP
I am running the 38mm rims on a spesh enduro 29er currently have hans dampf/magic mary 2.35 on, and previously had mountain king 2.4's on with absolutely no problems.
Posted : 01/11/2015 11:42 am
Page 19 / 21
