Light 20mm axle for...
[Closed] Light 20mm axle forks
[#2094101]
What are the options without spending a fortune? (travel 120mm - 130mm ideally)
Has anyone used any of the more recent Manitou Minute forks?
Posted : 16/10/2010 7:39 pm
Yep, Manitou Minutes are lovely forks. There are several different versions though. I had the 2008 Elite Absolutes in both 100 and 120mm and also briefly owned a pair of Minute Comps (coil sprung so couldn't manage to get a spring soft enough for me - they'd been misadvertised as air forks 🙁 ). The damping adjustment on the Absolutes ranges from full squish to fully locked-out in the first few clicks and was easy to adjust on the fly. Oh and they felt waay stiffer (and lighter) than the 130mm q/r Bombers they replaced.
Posted : 16/10/2010 7:51 pm
...Has anyone used any of the more recent Manitou Minute forks?
not yet, but they're in the post 😀 (hopefully)
Posted : 16/10/2010 7:54 pm
anotherstan - what model did you go for?
Posted : 16/10/2010 7:57 pm
@ conqueror, minute mrd, with 20mm hex lock, 130mm travel at only 3.76lbs 😀
Posted : 16/10/2010 9:03 pm
For 120mm, you'll get Rebas
Posted : 16/10/2010 10:10 pm
got 120mm bolt thru and 80mm qr 29er minutes.
love both of them. the 26" ones are really nice to use. most simple ones are more reliable i believe. light, smooth, easy to adjust, so far reliable (just about to be sent for their first service after over a year of use).
ONLY issue is that the hex-lock is a pain in the ass. 5 bolts, and on the disc side my multi tool interferes with the rotor, so you can't just spin the bolt so easily. i think 2011 ones will be coming with a QR bolt-thru...
Posted : 16/10/2010 10:24 pm
Rebas. Brilliant performance, decently light, rocksolid reliable and not badly priced.
Posted : 16/10/2010 11:02 pm
