Lezyne Alloy Dirt F...
[Closed] Lezyne Alloy Dirt Floor Drive
Bought one of these track pumps about 6 months ago based on recommendations for getting tubeless tyres inflated without a compressor. It certainly does that without any problems but I've always thought the pressure gauge was a bit off.
Having recently bought a Topeak smart guage which seems to be very accurate according to reports, my cheapish track pump that lives in the car appears to under read by 3 PSI whereas the expensive Lezyne under reads by 10 PSI. That seems pretty poor considering the price but is it a genuine fault and worth returning or just a trait of these pumps? I can certainly verify the pressures with the Topeak gauge but it would be nice to get them at least close to accurate with the track pump.
Posted : 17/06/2014 2:18 pm
Yep my Dirt Drive shows around 15psi when there's around 25 in the tyre.
Noticed the first time I used it.
Not really a problem for me as i go on feel of the tyre not what the gauge shows.
Posted : 17/06/2014 2:24 pm
Mine's spot on but it is brand new ๐Ÿ˜€
Posted : 17/06/2014 2:28 pm
Bought mine for the same reason.
Really disappointed that the gauge not at all accurate. Same as above about 10-12 psi off. ๐Ÿ™
Posted : 17/06/2014 2:46 pm
Oh. Not just me then.
I think the accuracy improves beyond 25(ish)psi but I could be wrong.
Would be interested in the outcome if anyone queried this as a possible fault with their supplier..
Posted : 17/06/2014 2:52 pm
Mine seems accurate in line with a digital gauge.
Posted : 17/06/2014 4:23 pm
 JoeG
I've had gauge issues with mine. ๐Ÿ˜•
I bought a Dirt Drive a couple of years ago. The needle stuck. Lezyne sent me a replacement gauge (but road psi). Then they sent the right one. I had trouble installing it. So they sent me a whole new CNC pump. ๐Ÿ˜€ It arrived with the top unthreaded but still in a sealed bag. ๐Ÿ˜• And it wasn't long before that gauge bottoms out at 5 psi. ๐Ÿ˜
I have to overfill the tire and use a handheld pressure gauge to check as I let air out. PITA!
Does anyone know of anywhere to get a non-Lezyne replacement?
Posted : 17/06/2014 6:19 pm
