Not just your custom builds I want to see your conversions (M960s to Jones cranks) etc. What have you done to make your bike and parts that bit more niche?
I think us MTBers have got slack with our personal touches, its common place in the fixy world (not that, that should be a blueprint).
Thats my favourite bike colour scheme. Loved them Zaskars.
built my own brakes from bits of xtr flappy paddle dual control shifters and re-machined straightline levers, lovely feel to them, they'll kill me one day
made my own 29er u turn forks (70-100mm) out of bits of revelations and reba 29ers as shown on this fugly monster
they haven't killed me yet either
at some point I expect to have a horrific bodging related disaster ๐
I give you...Frankenbike.
[url= http://farm5.static.flickr.com/4023/4641090341_94c3987844.jp g" target="_blank">http://farm5.static.flickr.com/4023/4641090341_94c3987844.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/4641090341/ ]21032010287[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Not shown this for a while on here:
[url= http://farm3.static.flickr.com/2195/2331062409_59652a38c0.jp g" target="_blank">http://farm3.static.flickr.com/2195/2331062409_59652a38c0.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/8133348@N03/2331062409/ ]IMG_3566[/url] by [url= http://www.flickr.com/people/8133348@N03/ ]oxym0r0n[/url], on Flickr
Polished cranks, frame has had cable stops removed, hanger removed and re-sprayed. Oh, and it's running ProIIs and Martas now.
@ Takisawa- did the project go any further?
Small fry compared to some of the above - but here's my 'Jones' modded XTR cranks.....
[url= http://farm5.static.flickr.com/4011/4322164083_b3f67f6c75_z.jp g" target="_blank">http://farm5.static.flickr.com/4011/4322164083_b3f67f6c75_z.jp g"/> [/img][/url]
I made a headset. once
My god, are you entering that in Robot Wars extreme? ๐
Next Mad Max movie.
It's not a bike anymore, it's a contraption.
Sorry, technical fail. I made a nice bike though, honest.
Well yeah, but it still works. In manner of speaking.
@richmars - That is quality! Did it last?
Me -
University project excuse to make a bike; a loong time ago!
[url= http://farm2.static.flickr.com/1117/542581928_30602d0957_m.jp g" target="_blank">http://farm2.static.flickr.com/1117/542581928_30602d0957_m.jp g"/> [/img][/url]
[url=
[/url] by [url= http://www.flickr.com/people/flamejob/ ]Flamejob[/url], on Flickr
And on Flameboy almost everything is home fettled...
[url= http://farm4.static.flickr.com/3497/4036338735_6d6ca3363f_m.jp g" target="_blank">http://farm4.static.flickr.com/3497/4036338735_6d6ca3363f_m.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/flamejob/4036338735/ ]Flameboy[/url] by [url= http://www.flickr.com/people/flamejob/ ]Flamejob[/url], on Flickr
Yes, but I don't use it. Made for the 'fun' of learning how to do it.
@ Ambrose, slightly but now mothballed till I get more time.
Stoner, that's a neat job and some clear pictures.
I thought about buying an On One frame once and it was the difficulty of using a Rohloff with it that put me off.
Isn't there still a chance that the torque arm will move within that gap as it gets wider when the wheel is further back ?
The torque reaction on a Rohloff goes both ways, depending on which gear it's in.
@richmars got any more photos - I'm fascinated. Did the bits come off an old Trek Y-Bike or something?
[edit just found them ๐ ]
Graham - the torque bar will move very slightly up and down until it contacts the dropout plate. It's a tiny movement and not at all noticeable. A bit of carbon paste or copper slip means there's no sound either.
The On-one/Lynskey Ti drop out plate is beefy as hell so has no problem with the set up.
It makes for a lovely tidy set up. IMO.
The reason I used this instead of a monkey bone was because i didnt want the expense of having to get a post mount caliper (which you need for a monkey bone) when I had a perfectly good IS XTR.
flamejob,
All frame bit home made, bike assembled from old bit I had. Only bit I brought was the shock. The rear suspension is modelled on a Whyte.
"the torque bar will move very slightly up and down until it contacts the dropout plate"
Isn't that a problem then ?
Below 11th gear, the torque reaction on a Rohloff is in the opposite direction to the wheel. Above 11th gear it is the same way.
I would have thought that as you went through the gears the torque bar would have taken up the slack, first one way, then the other, rotating on the single mounting bolt until it worked loose.
If it's working OK so far, then fair enough.
I had to modify my speedbone to fit a Chameleon, then a Gary Fisher Rig as the outer face of the caliper mounting is not flat.
I'll take some pictures next time I've got the bike at home.
the mounting bolt threads into the frame, not the torque block. SO it can be threadlocked to the frame without binding the block and not precess.
the torque bar only changes direction as you cross the middle gear.
as I mention the movement is less than a mm if you file the torque block accurately enough.
firestarter, that fixed cog's neat and simple, i like it.
My M960s arrived today ready for the Jones conversion.
I had originally tried a set of polished m952s, but they were'nt pretty. Second time lucky..
I will keep you posted as I get them done. I will be using ajantom's as a template.
Good work rickmars fantastic project, any more pic? I know a guy who built a carbon bike based around an inbred, all done in his kitchen.
ir_bandito Love those midges. Did you just use some caustic soda and then polish?
I chopped a Brooks B17 yesterday...but it's on the fixed so doesn't count.
@Jef Wachowchow I scribbled the frame on AutoCAD and it was made by some Chinese people that are really good at making titanium things. All the components were sourced and polished by me (mainly nice old stuff, plus rohloff and Chris King). I also polished flames into the frame.
Here's the modifications I made to a Speedbone so I could use a Rohloff on a Chameleon and a Gary Fisher Rig.
The problem is that the outer face of the caliper mounting is not flat, the bolts are recessed.
[url= http://farm6.static.flickr.com/5163/5292857010_86886d1e21.jp g" target="_blank">http://farm6.static.flickr.com/5163/5292857010_86886d1e21.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/8805115@N04/5292857010/ ]Picture 011[/url] by [url= http://www.flickr.com/people/8805115@N04/ ]Vegan Graham[/url], on Flickr
I hacksawed, drilled and Dremelled the aluminium away, then made two steel spacers to locate in the recessed bolt holes.
[url= http://farm6.static.flickr.com/5286/5292853342_44daa3a312.jp g" target="_blank">http://farm6.static.flickr.com/5286/5292853342_44daa3a312.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/8805115@N04/5292853342/ ]Picture 012[/url] by [url= http://www.flickr.com/people/8805115@N04/ ]Vegan Graham[/url], on Flickr
[url= http://farm6.static.flickr.com/5045/5292855740_1b3cb893f1.jp g" target="_blank">http://farm6.static.flickr.com/5045/5292855740_1b3cb893f1.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/8805115@N04/5292855740/ ]Picture 013[/url] by [url= http://www.flickr.com/people/8805115@N04/ ]Vegan Graham[/url], on Flickr
Nothing special, but it may help someone else who's faced with the same problem.
[URL= http://inlinethumb29.webshots.com/45340/2330503920103304323S600x600Q85.jp g" target="_blank">http://inlinethumb29.webshots.com/45340/2330503920103304323S600x600Q85.jp g"/> [/IMG][/URL]
3 wheeled death chariot
LOL.
but what do you do with it? have tea breaks/lunch on it?
More Rohloff modifications.
I wanted to fit a speedbone to a Kona Big Unit.
With the slider fully forward, the speedbone fouled the frame.
I hacksawed and filed the chain tug lug off the slider as I don't use the adjusting screws anyway, then Dremelled a bit of the speedbone away to clear the frame.
