lefty wheel not com...
[Closed] lefty wheel not coming off...
my lefty front wheel wont come away from the fork.
in fact when I turn the allen key the plug seems to pop out of the treads
hoping its the threads on the plug and not the hub
Posted : 10/10/2016 11:55 am
Do you still have to undo the disc caliper to get the wheel off??
If so...you have done that, haven't you?
Posted : 10/10/2016 12:06 pm
What he said.... ^^^^
Posted : 10/10/2016 1:15 pm
๐Ÿ˜ˆ good call from Stumpy, but otherwise my 'old' style lefty, if you've gotten the axle bolt completely loose, then (as long as the caliper is removed) the wheel will come off.
Posted : 10/10/2016 1:29 pm
yep caliper is removed .haha
when I wind the nut, instead of the wheel being pushed away from the shock. loads of pressure seems to build up behind the cap and then the cap pings out. I think the threads are goosed.
Like I said I hope its not the threads in the hub.
when the cap is removed I can wind the nut all the way out (basically not threaded into the fork) but the wheel still will not budge.
not sure if I need to get the rubber hammer out - or remove the disc and get the wd40 out
Posted : 10/10/2016 1:50 pm
Sounds like the bearings have seized onto the axle and hence the bolt is unwinding (but not pulling the hub free), building up tension, and then popping as it either reaches the end or has pulled a thread.
You can take the cap off the outside with a pin-spanner to inspect the bolt and end of axle threads to see if you've done any damage, but getting the wheel off now sounds like its going to need some careful persuasion (possibly with a rubber mallet and block of wood against the inside of the hub face...
Posted : 10/10/2016 2:05 pm
...A GOOD OLD FASHIONED WHACK THEN ๐Ÿ™‚
Posted : 10/10/2016 2:37 pm
