Lefty on a 44mm Hea...
Lefty on a 44mm Headtube bike….
Just trying to plan logistics for a potential build. I have a lefty and would like to run it on a 44mm Headtube frame. Is it a case of a different upper headset cup to allow for 1.5inch steerer? Or do I need to find an adapter? I know there are project 321 adapters but I assume they’re mucho expensive. What’s stopping me using a spare generic tapered steerer and then finding a shim for the upper lefty clamp? Just pondering ideas but feel free to shoot me down!
Posted : 24/08/2024 1:05 pm
clubby and clubby reacted
As someone who has run Leftys on a couple of non Cannondale bikes over the years the proper adapters are the way to go. I have 2 of the Lefty 4 All adapters and a Project 321 steerer. With both of these you get a ful suite of clamp adapters.
You need the lower “piece” of the proper adapters  for the lower clamp to clamp to - there is then a mild bulge for the crown race. The only time I’ve run one tapered was on a internal lower bearing arrangement otherwise you often end up with a too larger space between the clamps.
For a 44mm HT 2 1/18” internal (IS41?) cups work best with the correct steerer.
I really like the Lefty but dependant upon which version you have depends how fanickity they are - e.g. bearing resets.
Often not a cheap experiment but a fun one!
This was 2012ish on a tapered HT:
IMGP2937_zps2e399637
Posted : 24/08/2024 1:38 pm
As a side note you need a 90mm (IIRC) to clear the fork leg … let me find a photo …
Found one - this was the same style fork as above on an Inbred 29er with a 1 1/8” HT
IMG_5480
Posted : 24/08/2024 1:41 pm
Cheers Mark, that’s helpful.
Posted : 24/08/2024 4:06 pm
