left handed shiftin...
[Closed] left handed shifting ?
came off the bike a few weeks ago, on a silly low speed unexpected crash and have largely bu**ered up my right hand for the forseeable.
I don't see me being able to change gear with the right hand comfortably for quite some time, so am looking at moving the shifters on all my bikes to the left hand.
which at first round of google searches doesn't seem to be as straightforward as I'd hoped. have just been playing with moving the shifter to the lefthand side of the bar, but the gear mechanism pokes out of the wrong side of the bar and looks kinda stoopid and to avoid interference with the brake the shifter is set at a silly angle, just doesn't look practical.
Any stwers managed to swap shiters to the left hand ? am wondering if i can open the shifter and transplant the internals of a 10 speed shifter to a 2-3speed shifter that is designed for the left hand side.
two bikes have shimano 10 speed and one has sram 11 speed.
Posted : 17/02/2019 7:35 pm
Would it work for you if mounted upside down(shifting levers above the bar) ?
Posted : 17/02/2019 7:38 pm
You need a Di2 upgrade
Posted : 17/02/2019 7:39 pm
SRAM 11sp grip shift should work on the other side (and are good for a knackered hand - from experience)
Posted : 17/02/2019 7:42 pm
 PJay
Would a grip shift & trigger be workable?
Lefthand Thumbshifter on friction.
Seen it done, and apparently it worked surprisingly well. You just had to get used to the gaps for each shift, and you can fine tune it easily.
Posted : 17/02/2019 7:43 pm
Grip shift on opposite side works very well.
Posted : 17/02/2019 8:22 pm
SJS have some 10 speed MTB thumbshifters in stock - could be worth seeing if you can mount the right one upside down on the left, or cannibalise two into one.
These ones.
Posted : 17/02/2019 8:23 pm
Just run the rear cable to the Lhs 2/3 shifter and work on your fitness with just 3 gears 😉
Posted : 17/02/2019 8:31 pm
will try this tomorrow and see if it works
Posted : 17/02/2019 8:55 pm
I'm sure i do, but don't have the funds to do three bikes
Posted : 17/02/2019 8:57 pm
SRAM 11sp grip shift should work on the other side (and are good for a knackered hand – from experience)
will try this on the cannondale, thanks
Posted : 17/02/2019 8:59 pm
You need a Di2 singlespeed upgrade
Posted : 17/02/2019 9:25 pm
Upside down should be workable - was standard practice with many dropper remotes until recently!
Posted : 17/02/2019 9:54 pm
A friend with 4 fingers runs his shifter on the left above the bars, he just had to adapt to it.
Posted : 18/02/2019 10:08 am
Just read this post from a few days ago - can you explain "thumbshifter on fricton"
can't imagine how this works...
Posted : 22/02/2019 1:53 pm
Shimano thumbies back in the day just was a lever with no steps so you just pushed till it was in the right position
Posted : 22/02/2019 1:57 pm
I Agree with 'friction thumbshifters' - but only if your using a low gear count 7/8/9sp
- imho the spacing on modern 10-11sp makes them much harder to 'trim'.
Posted : 22/02/2019 5:26 pm
Gripshift would be my suggestion if you need a front mech to go with it, mount an older (possibly friction) thumbie inboard...
Posted : 23/02/2019 1:34 pm
sram gripshifts only work with sram rear and front mechs. Shimano do gripshifts too although they are called something different and I am not sure what gear range they do them in.
Although a gripshift is probably the best option surely the cable routing will be odd and might not work too well. Do European bikes have different gripshifts as they use the brakes opposite to us?
Posted : 23/02/2019 1:39 pm
Sram did make shimano compatible gripshift up to 9 speed but, point taken, if you want 10/11/12 speed yes you're going to need a sram rear mech... But it's really not so terrible, they do actually work still despite not being all shimanoey...
Posted : 23/02/2019 3:32 pm
