Left hand threads o...
Left hand threads on Manitou Forks - Why?
I'll be servicing a set of Manitou Circus forks soon. The lower leg bolts are left hand thread. Why?
I can't figure out any reason why they would need to be LH thread.
Here's an example on one of their service videos:
Scroll to about 1:30.
Posted : 30/11/2023 1:48 pm
Because the lowers go on backwards
Posted : 30/11/2023 1:52 pm
thols2, Rubber_Buccaneer, dyna-ti and 3 people reacted
Because the damper actually threads into the bottom of the lowers. You're not undoing a nut like on Fox/Rockshox, you're undoing the damper from the bottom so it releases from the lowers. The damper threads the correct way but you are unscrewing from the opposite side
Posted : 30/11/2023 1:54 pm
they aren't... you wind the damper and airspring rods out of the lowers/lower nuts, you don't undo the nuts
Ah this makes sense now! Thanks.
Off to find a torque wrench that does 4 nm counter-clockwise...
Posted : 30/11/2023 5:42 pm
kelvin and kelvin reacted
Off to find a torque wrench that does 4 nm counter-clockwise…<br />Posted 12 minutes ago<br /><br />
I’d just twizzle it clockwise for a feel of what 4nm is like. Then do it backwards. It’s really not much at all.
Posted : 30/11/2023 5:56 pm
As above, just get a feel for 4nm then guess. And a good tip is to use a short Allen key or hold a longer one nearer the tip so you can't put as much torque into it
Posted : 30/11/2023 7:31 pm
Like pedals and bottom brackets. It's to protect against mechanical procession
Posted : 30/11/2023 7:44 pm
