Lazy brake lever
[Closed] Lazy brake lever
Hi all,
Sorry if this has been asked. I have an Avid Juicy 5 brake lever that does not return back sharply. Its very slow. Is there any way to sort this? I have bled the brakes early in the year with the kit as per Avid youtube video.
Posted : 20/10/2009 7:13 pm
sounds like a seal might of come off...but it might just be dirty...but i had some fives for a year and a half...used abused and never properly cleaned apart from when it rained...they never faultered so id say its a seal or sumthing similar.
Posted : 20/10/2009 7:25 pm
Try lubing the pivots?
Posted : 20/10/2009 7:32 pm
DON'T USE TEFLON LUBE IT ****S UP THE SEALS
Posted : 20/10/2009 7:33 pm
can the lever be removed without opening up the brake itself?
Posted : 20/10/2009 7:56 pm
yes
Posted : 20/10/2009 7:59 pm
ROFL
can you provide any help on doing this?
Posted : 20/10/2009 8:02 pm
yup
undo the grub screw, push out the pivot, pull the lever, the piston head pops out - job done
Posted : 20/10/2009 8:03 pm
thanks; i'll try that.
Posted : 20/10/2009 8:05 pm
