Last two times I've driven to Evans (13 miles) to buy something I needed - in lieu of ordering online and waiting a couple of days - I've completely wasted my time.
Last time it was a single speed chain, now it's tubeless rim tape.
Hell even Halford's the other day had no C02 cartridges.
What's the point of even going to a bricks and mortar store now! 😀
Even Homebase was out of methylated spirit's the other day.
No I don't drink it 😀
Maybe it's Brexit come early and time to stock up on beans and bottled water? 😀
What happened when you visited the lbs that you won't go back ? You seem to have missed that part of the story.
Why didn’t you ring them first if it’s so far away?
My 'LBS' is 45 miles away, I sometimes go for a ride out & to be called names. Sometimes I buy something, sometimes I don't but usually they have what I want. (Bike Scene, Guisborough)
Your LBS sounds like shite.
Youv'e already made 2 mistakes OP. Evans & Halfrauds are NOT 'Local Bike Shops'
Did you check the store stock online first to avoid wasting your time?
THIS
I've done this many a time when in need of something same day. Item in stock = I'll pop on down and pick it up. Job done.
If I need something urgent and can't source it from the spares box I always ring before I set off out. Last thing was a bottom bracket a couple of Sundays ago when I made a mess of removing the drive side one. Quick phone call to James in Rotherham and was sorted. Would never dream of turning up on the off chance they might have something in stock.
Both items are niche items in the grand scheme of things.
Pish rant.
You an check Evans stock online which I use all the time due to the number of stores they have, check online then call to put aside you cant go wrong this way.
I ordered somw waterproof sox online from Evans this week. The first email said available in 2 days but please wait for an email to say they are definitely at your chosen store before journeying for them. Did you get an email to let you know the goods were ready for you?
Tbh the couple of times Ive done this with Evans Ive had great service, its the B'ham store btw.
Evans do click and collect where they will send it to store next day. So basically user error.
I opened the fridge this morning and saw half a pack of bacon but realised I had no rolls so went to my local shop. Only by the time I got there it wasn't morning anymore and just as I walked in I saw a wee boy place the last two fresh rolls in a bag and into his dad's basket. I ended up buying a sausage rolls and a pie instead. Not a bad day exactly.
I can sympathise with the OP, I'm careful at Evens now, I ordered a 105 chain and picked up from store, I got home to find out it had no fitting pin, or split link.
It now has a very tight join that even though I've tried to sort won't become un-stiff
@scratch
Assuming you joined your new chain using a chaintool and are struggling to use the tool to free the stiffness from the join.
First visually check the stiff pin you joined the chain with is showng through the outer plate by an equal amount.(if it's not. carefully even it up with your chaintool)
Next hold the links either side of that pin and rotate the join so that they are at 90deg to each other.
Now keeping the plates at 90deg forcefully twist (wiggle) the narrower link both ways.
Next rotate the join so the links are at 90deg the other way and repeat.
Your stiff link should now rotate freely arond that pin.
this is just a little no tools method of freeing any stiff link. Once you're used to this method it's easier than using the chaintool to create an even gap.
My local Evans has no bike racks, I had to lock it to a street sign round the corner and walk 100 yards.
Sounds like the OP buys online then expects local shops to have anything he might need in stock.
Go figure.
OP will be happy in a couple of weeks. There will be plenty more snowflakes to keep him company.
Evans let you take bikes into the shop ya big silly.
People buy CO2 carts from Halfords?!
Aldi always seem to have a stock of CO2 cartridges in the sale isle
I went to my local Evans after they had closed for the day. They were closed! ☹️
Last time it was a single speed chain, now it’s tubeless rim tape.
Yup, both things bought by less than 0.1% of cyclists who think of Evans or Halfords as a “LBS”
Should have tried sports direct oh wait you already did bugger
Always phone up if I specifically want something whether an lbs or tredz/Evans etc. However, last time I phoned tredz I got “I can’t see from here, you’ll have to come on down” 🤬🤣
This thread not going the way you though it would OP?
Did they have any nice ebikes though?
I have had a good experience today. I was replacing a hydraulic hose and realised I didn't have a 7mm spanner for the bleed port. A quick trip to halfords sorted that. Then I managed to lose the olive. A quick trip to my lbs sorted that. To be honest I haven't visited that shop since about 1995 when I bought some manitou forks for my Marin but the chap was very helpful.
they probably packed up and went home to celebrate after that sale. one of those every 23 years should be enough to keep them open
Tubless tape should be in stock Shirley, at least some in the workshop?
That doesn't exonerate the op from a good shake and 'pull yourself together', though.
Not really an essential in most shops. Probably only a very small fraction of 1% of cyclists run tubeless.
they've probably got tubeless tape though 😉
I don’t think the OP needs tubeless tape, he set his wheels up without it with no complaint surely.... 😜
I drove to Oxford this morning, circa 20 miles. I couldn't find an Evans anywhere.
To whom should I complain?
"My ‘LBS’ is 45 miles away" eh? should that be L.D.B.S.?
Wouldn't you just ring a mate and ask to have some of their tape? Then replace at a later date?
My local Evans has bike racks inside the shop for customers
I have I think 6 bike shops I can go to in Cardiff. If I want something specific I always ring round each one and check if they have it. Due to the sheer amount of specific stuff keen cyclists might need you can't expect shops to have everything in stock. There are thousands of low value items that might sit on a shelf for years and only fetch a few quid in profit. It's just not worth it.
Bikes though - most people around here seem to have bikes bought from one of the local shops, so it would seem more lucrative for them to stock bikes.
Top trolling from the tow path exocet to be fair....
My local Evans only sells women's clothing.
As long as they stock your size happy days 😉
Can you get pencil skirts in 650B?
No but you can in plus sizes
I like browsing my old local Evans, but I'm wouldn't use the workshop after the head mechanic was adamant you couldn't get a 30mm bsa bb. Time to excuse yourself and walk away.....
Mine have been great as usual - gear outer, copper slip, a headset for a new SH frame that I couldn't find online, an outer hose connector tool for threading gear outer, seal kit and fork service and decent cheap lock on grips. 4 Play Cycles in Cockermouth (I know...) and Keswick Bikes. Long live the LBS
Ive always found Evans to be fine, although I thought their clothing range was a bit of a selection of odd choices. The rest was pretty good though. My local one in Durham is closing apparently which isn't great for the people who work there 🙁
I can't comment on whether its profitable, but I can comment on the fact its in a very high demand area for retail, being on probably the most popular trading estate. Im thinking that SD might have asked for a discount and being told to get on their proverbial bike... if that is the case I can see why they would say half will close. Assume a 50% success rate for negotiating a significant rent discount, close the rest.
^ A better success rate than that so far Ben, thankfully. In some areas stores will simply move - SD own some large sites.
I was in the Glasgow Braehead one at the weekend - one of the staff said that as things stood it was scheduled to close sometime in the new year with no word what was happening after that, hopefully if it does close it pops up somewhere nearby for the sake of the staff, always had good service from the people there.
Shout out to Manchester Deansgate branch of Evans. Pedals and tubeless sealant in stock yesterday, and pedals pricematched with no problem. 👍
Jameso, any inside knowledge on the Lakeside store?
^ no sorry, I'm not involved with the stores side of the business that closely. I heard the plans weren't at the extent of early reports though.
^^ Thanks, they are good guys and there aren’t many alternatives for me
