Large bike bag.
Large bike bag.
[#12578958]
Afternoon collective hive mind,
Does anyone know of bike bags Taht accept large bikes?
I have a S6 Stumpjumper Evo and am struggling to find one to fit, I've tried a friends Evoc bag and the frame is roughly 20-25mm too long! Wheelbase is 1319mm.
Thanks.
Posted : 14/10/2022 2:37 pm
Not all EVOCs are same - worth checking on their website as I remember a table showing the different models and years as dimensions have even changed for same model over the years
Posted : 14/10/2022 2:40 pm
They do two sizes of Evoc, was your friends the XL or normal size? I guess letting all the air out of the fork and compressing the shock wouldnt get it into the Evoc bag?
EDIT: The Pro bag does up to 1300mm wheelbase, the S6 is listed as 1319mm so still slightly too long!
The crc wiggle Pro ones may fit 1400mm.
[s] On an aside, how is the stumpy? Trying to find one in s6 to test ride and struggling! [/s] ah, evo, never mind
Posted : 14/10/2022 2:41 pm
Evoc Pro fits my Geometron G16 at 1324 wheelbase
Two things - turn your fork so it faces backwards, and if necessary, let the air out of your fork. I do the former, so don't need to do the latter, but you can shorten your wheelbase a lot that way. Also the option of unbolting your shock which shortens even further.
Posted : 14/10/2022 2:50 pm
the Polaris Axial Pod Bike Bag should do - mine fits a gen 3 large RocketMAX with no issues and a mate has put his XL (XXL?) Pole into his.
Posted : 14/10/2022 3:23 pm
Polaris is a bit bigger than an evoc
Posted : 14/10/2022 3:27 pm
Here's the table I saw....
Until Season 2018: BIKE TRAVEL BAG PRO inside: 130 x 27 x 78 cm (maximum wheel base: 124 cm)
From Season 2019: BIKE TRAVEL BAG PRO inside: 136 x 27 x 80 cm (maximum wheel base: 130 cm)
Until Season 2018: BIKE TRAVEL BAG inside: 128 x 27 x 78 cm (maximum wheel base: 122 cm)
From Season 2019: BIKE TRAVEL BAG inside: 130 x 27 x 80 cm (maximum wheel base: 126 cm)
From Season 2021: BIKE BAG PRO inside: 147 x 36 x 85 cm (maximum wheel base: 130 cm)
From Season 2021: BIKE BAG inside: 138 x 36 x 85 cm (maximum wheel base: 126 cm)
ROAD BIKE BAG PRO: inside: 130 x 92 x 53 cm (maximum wheel base: 112 cm)
Posted : 14/10/2022 3:42 pm
Cheers guys, tops hive mind as usual! Will try my friends again as I still have it, this time I'll try compressing the fork/shock and see how it goes.
Posted : 14/10/2022 7:17 pm
I've a polaris in sw Scotland you could borrow
Posted : 14/10/2022 8:28 pm
