Lapierre down post ...
[Closed] Lapierre down post dropper cable guides
After buying my Lapierre Raid fx earlier this year (I'm a newbie at 43 take the p1ss if you wish) I have now garnished it with a Rockshock dropper seat post.
While routing the cable along the down post I have noticed the cable guides (3 of) only allow space for three cables.
They are all X shaped and looking at them from underneath, one side holds one cable and the other holds two.
Any ideas if there are ones in existence that hold 4 cables around or not?
All the ones I can find on google don't say if they are the same as the original ones and are out of stock anyway.
Posted : 30/04/2015 8:15 am
If they are the same as on my 2014 Zesty (looking at a stock pic via Google it looks like it) there are 3 X shaped fixings that secure via a central allen bolt. They should hold 2 cables/hoses either side of the bolt (dropper, F & R mech and rear brake). Mine only hold 3 as 1X at front now, but did hold 4. If it is a symmetrical X I am surprised that you can only fit 3. Just undo the allen bolt enough to slip another cable in and re-tighten.
Posted : 30/04/2015 9:33 am
These are all definitely holding just 3 cables.
There's a single curve on one side and a double curve on the other.
Posted : 30/04/2015 9:38 am
Loop a small cable tie to the other cables loosely to give you a movable guide for the dropper cable to run through.
Posted : 30/04/2015 9:47 am
keng38 - Member
Gotcha. Well the 4 cable versions are available then.
[url= http://www.hotlines-uk.com/lapierre-ano-downtube-dropper-cable-guide-2013-prod95134 ]Link to an overpriced bit of aluminium[/url]
Otherwise just use a few black cable ties as suggested.
Posted : 30/04/2015 10:05 am
Ouch if that price is each and not a set of 3.
Cheers for the help.
Posted : 30/04/2015 1:37 pm
