Community
Kona Unit - sizing
[Closed] Kona Unit - sizing
Looking to press the button on buying a 2013 Unit through the bike to work scheme, bit stuck on sizing. Am 6" 4 (35 inch inside leg) and can't decide between the 20 inch or the 22 inch - worried the latter would be a gate.
Unfortunately I have to order in advance through Halfords so don't have a chance to try one unless I schlep to the nearest dealer and frankly I'm too lazy.
Any owners got a view?
Posted : 13/11/2012 3:46 pm
I know that I'm nowhere near your height, but possibly of some help with regards to seat tube length.
I'm 5ft 7 with a 31.5 inch barefoot inside leg and ride a 16" Kona Unit.
I run a 410mm Thomson setback post and a seat height of 73cm from the centre of the bottom bracket to the top of the saddle (measured straight up the seat tube) and this leaves me with 120mm of post left in the frame.
The centre to centre seat tube measurements on the Unit's are really small. My 16" is only 13" centre to centre, so even with 120mm of post in the frame; it only leaves 2 cm's below the sest tube / top tube junction.
Posted : 13/11/2012 3:55 pm
I'd say 22".I had a 20" and at 6'2 it was'nt huge by any means.
Posted : 13/11/2012 4:03 pm
great thanks guys, very helpful. I'll risk the gate!
Posted : 13/11/2012 4:35 pm
 Keef
[*]I've had a 20",spot on 6'tall, 34" leg.
you need the gate ๐Ÿ˜‰
Posted : 13/11/2012 5:01 pm
