anyone used one of these to run a 24mm crank in a Pressfit 30 frame?
seems an alternative to a PF30 and problem solvers?
http://clee-cycles.co.uk/esite/P20004/product
Not used that one. But do use the praxis works one that does the same thing
Fitted it in November and still fine , which means its lasted longer than some pf30 bb
praxis works
will look that up, did not find that via google.
ta
http://praxiscycles.com/
Upgrade are the uk importer
Chain rings look very good but not tried them yet
Second the Praxis one. Sram also make a PF30 adaptor you can screw a normal BB in to. I've got one so I can try it when my Praxis works one wears out.
FSA do them too - CRC sell them. I have one, bought in error if you're interested.
yer saw that just thought the KCNC effort looked like a neater solution.
ta
[quote> http://praxiscycles.com/
cheers OB, i found praxis easily once you had mentioned it, but it did not come up when searching for PF30 stuff.
ta
