Anyone used or seen this.... Love the look of it, curious to know if anyone has one (I've seen other models but never this karcher one)
[url= http://amzn.to/2tSMK4X ]Karcher powers wash click here[/url]
That was my initial thought, however if the power is right it may be enough to get the worst of the much off.
A mate has a home made 20ltr one that will use all the water doing one bike (because of the flow) yet my mate has a 17ltr that will do loads of washes as the flow is alot less.
http://singletrackworld.com/forum/topic/anyone-used-one-of-these-for-cleaning-the-bike
I'd rather have one of these.
I see your point regarding flow vs pressure (a pressure washer uses a lot less water than a hose), but a) more pressure is worse for seals and b) any less flow than a normal 17l mobi/other and you will be there for hours.
It might work OK with a second 5l water bottle on standby to refill.
My Nomad is 14 litres I think - usually OK for a couple of bikes unless it's really claggy.
Could probably get away with 5 litres for a single bike if you don't mind giving it a brush off first.
