Kaffenback - max ty...
[Closed] Kaffenback - max tyre size without mudguards?
8 Users
I'm sure this has been covered a hundred times but can't find anything on a search.
Is 32c really the largest you can get in there?
Posted : 06/01/2011 3:16 pm
Yeah, I've been told that Conti Twisters 32c are about the biggest you can sensibly get in there.
Posted : 06/01/2011 3:27 pm
I had some 32 somethings. Specialized Houfailise (Spelt badly wrong I know)A fairly round profile. they damn near filled the dropout. Doubt much bigger would go.
Posted : 06/01/2011 3:45 pm
IIRC there is more space in the back end than the forks.
Uncle John is the way to go if you want bigger, but i reckon my Tricross would fit pretty big tyres in too.
Posted : 06/01/2011 3:58 pm
can get a 35c slick in a pompino (same back end iirc)
Posted : 06/01/2011 4:10 pm
Ok thanks all.
Posted : 06/01/2011 4:38 pm
But the horizontal dropouts on the Pompino means you can put the wheel a bit further back, to get more space for the tyre.
Posted : 06/01/2011 5:24 pm
32mm twister is tight, any significant buckle in a rim and it would rub the stay. I panic cut all the side knobs off mine the night before touring on it.
Great bike by the way
Posted : 06/01/2011 5:28 pm
I can get a 32mm Cyclocross tyre on a Kaffenback, and with the knobs it's probably a tad larger than a slick with the same carcass size.
Right enough there is about a cigarette papers clearance at the seat tube and stones in the tread gouge the seat tube, but it's a working bike etc. 😆
Posted : 06/01/2011 5:45 pm
