Just split up with ...
[Closed] Just split up with my girlfriend, help me understand why.....
......My Chris king race does not fit my old pace forks. both are 1 1/8th
Is there some sort of fix for this.
(sorry for the Title, it does seem like the only way to get people to reply to threads on here these days)
Posted : 23/09/2009 2:47 pm
Get a girlfriend and stop worrying about bike bits.
Posted : 23/09/2009 2:49 pm
LOL, run a file around the top of the steerer, to make sure there no lip stopping you put the race on.
boiling water, dab of grease, some waste pipe, a gert big hammer and some MTFU.
LOL ๐Ÿ˜‰
Crown races are an interference fit (eg the hole is slightly smaller than the shaft (on topic, see!) so some combinations are just b@stard tight. If you're really struggling, just cut a slot in the crown race - works fine for cartridge bearing headsets though obviously no good for ones with loose balls (on topic again!)
Posted : 23/09/2009 2:50 pm
Shame, this could have been another 100+ thread!
^What he said^
nah it will fit its just super loose. the pace forks dont seem to have a bulge in the steerer as required by the CK race
Posted : 23/09/2009 2:51 pm
if it's super loose you coul dmake a very fine coke can shim to stop the race moving fore/aft. It wont move up and down because of the pre-load.
Posted : 23/09/2009 2:53 pm
Ah right, well some forks did have a staight steerer with a separate stepped ring to fit at the bottom so that the crown fitted - sounds like that's what's missing.
Super loose fit - on topic again...
[i]"it will fit its just super loose"[/i] Race or g/f?
ta booom!
Posted : 23/09/2009 2:54 pm
Just put a dab of locktite 243 thread lock behind the crown race. Once the headset is preloaded it wont make any difference anyway.
Unless of course it is literally rattling around the steerer in which case the old coke can shim maybe necessary.
She dumped you because you're obsessing about the fit of your ring?
Ian
Posted : 23/09/2009 2:59 pm
cheers all,
crazy but it worked....check out the last time I posted that question how many replies I got.
First stop then to speak to pace to see if they have what clubber was talking about....if not then a coke can it is.
as you were.
What clubber said. The old Pace forks had an extra ring.
Your girlfriend knew this and left you for someone Cytech certified.
Posted : 23/09/2009 3:00 pm
As long as it's not flapping about around the steerer it'll be fine, I have two sets of reba forks that the races just slide onto, no problems whatsoever, as above once it's preloaded it's all nice an tight anyway.
Posted : 23/09/2009 3:01 pm
my bombers always had a loose crown race, no issues, although that was with a lose ball headset so more tolerant of shitty alignment than cartriges that seem to self destruct if not perfectly fitted.
Posted : 23/09/2009 3:09 pm
 juan
Dont move I tell your GF you can't fit a headset...
She just asked for her personal belongings to be posted back ๐Ÿ˜‰
Posted : 23/09/2009 3:18 pm
Nah this is loose. I can fit a flat head screwdriver between the race and the steerer. it sounds like something is missing as clubber said.
Posted : 23/09/2009 3:21 pm
Sounds like your missing the little step washer, call to pace required
Posted : 23/09/2009 3:33 pm
Don't try shimming with Coke can, I've tried and the amount of shim is far too great. As above, you need a Pace Race Collar, effectively a crown race shim.
Posted : 23/09/2009 3:36 pm
My Pikes wouldn't accept the crown race onto the flared bit at the bottom of the steerer. Tried everything, but it just wouldn't go on. Finished up filing down the bulge. Now fits perfectly.
Posted : 23/09/2009 4:00 pm
