Just had great cust...
[Closed] Just had great customer service at LOCO
 Twin
Just had an aircan volume reducer fitted at LOCO. Cup of coffee, a chat, work done at a great price. What more could I ask? (I did take Welsh cakes though!)
Cheers Simon!
Posted : 05/04/2013 1:10 pm
Yep, can't recommend him enough.
Gonna send my RP23 down to him next.
Great guy and service.
Posted : 05/04/2013 1:15 pm
I concur, excellent service. 🙂
Posted : 05/04/2013 1:18 pm
also had good service from loco, top guy....
@twin, surely you could have done the spacer yourself..it takes all of 3 mins to that job? you don't even have to take the shock off the bike!
Posted : 05/04/2013 1:22 pm
He's *gurt lush*
Posted : 05/04/2013 1:23 pm
How could you leave it on the bike when you have to remove the body to put the spacer in?
Ah wait you just slide the body down to the shaft end?
Posted : 05/04/2013 1:25 pm
@twin fella you need to learn when your in Wales they are called Bakestones 🙂
Posted : 05/04/2013 1:27 pm
@ mosey, yup
let air out
unscrew can
pull down metal washer from up inside top cap
insert spacer and a little float fluid if needed
screw up can
inflate.
Posted : 05/04/2013 1:34 pm
 LoCo
Cheers Twin and everyone else 😀 Full of Welsh cakes/bakestones now 😳
and yes you can fit them yourself, had a large that was machined down to medium size rather than Twin having to buy 3 at £18.20 and had an air can service at same time along with a quick check on the damper and a clean. 😉
Posted : 05/04/2013 1:39 pm
Ah ok, the video I watched removed all mount hardware too but I see its not needed.
...sssh
now you've told him what is involved, there'll be a 'LOCO - **** ripoff' thread
 LoCo
£10 for a a custom spacer, air can service damper check and clean 😉
Posted : 05/04/2013 1:41 pm
cheap at half the price...you did a very good job on my DHX4air just after christmas
Posted : 05/04/2013 1:43 pm
Damnit if I could put cakes in my email he might reply ? 😉
Posted : 05/04/2013 1:54 pm
Maybe you could try attaching a picture of some cakes to the email - it might be an aesthetic thing? 🙂
Posted : 05/04/2013 1:56 pm
 LoCo
13 mins and already a no reply 😉 I don't just sit at a computer all day (thank goodness) 😛
Will reply in a mo 😀
Anymore cake, Icake or real with make me sick 😳
Posted : 05/04/2013 1:58 pm
Thank chuff you're on here enough to have a sense of humour :mrgreen:
Posted : 05/04/2013 2:46 pm
Loco I sent an email via your webpage over a week ago about the lock out on my revelations but had no reply??
Posted : 05/04/2013 2:57 pm
 LoCo
Have replied to a mail hiding in the mail system, think it should be yours 😀
Posted : 05/04/2013 3:08 pm
Parp that was quick !!!
cheers
Steve.
p.s I took the lockout bit off the top of the fork leg and couldn't see a spring?? is it internal to the fork?
Posted : 05/04/2013 3:14 pm
 LoCo
The compression damper has the spring inside, unsure wg=hich compression damper/moco you have in the fork, pop a picture over and I can give you a better idea of how to proceed.
Posted : 05/04/2013 3:19 pm
