Question as per title! It arrived today. Do I need to buy another bracket/strap from somwehere?
Thanks!
they sell them on the same site don't they?
Did you get the headlight or the bike mount version?
THe accessories are [url= http://www.dealextreme.com/search.dx/search.29489 ]HERE[/url]
You need a headstrap and the extension cable if you want the battery in a back pack rather than on your head.
OOPs - double post.
I bought the headlight version but, and I am probably being a bit thick here, I can't work out how to arrange the strap thing to fit the light on the helmet...
If I try to put it on top of the helmet it doesn;t work very well, and I cant put it on the front of my forehead (under the helmet), because it would foul the helmet...
I didn't even bother with the mount they sent, just used the 2 rubber rings (one doubled through the other) to make it long enough to loop through the helmet.
luckily my helmet has a section that the light can sit on in the centre.
Otherwise Mountys suggestion looks good.
could do with an extension lead - anyone got a link to it?
Ok, looks like a bodge is in order. I will award myself bonus points if it's easily removable for road rides.
What are the connectors like on the magicshine? I notice they carefully don't show them in those photos.
I presume they are standard sized jacks and the cables can actually be either cobbled together easily enough
