Juicy ultimates and...
[Closed] Juicy ultimates and Hope floating rotors
Hi, i want to increase the size of rotors on my ultimates, and quite fancy some hope floaters. Has anyone done this? Any clearance issues with the rivets?
Posted : 22/03/2009 10:43 pm
Fine when new, but as the pads wear the legs on the bottom catch the rivets. (I know of a slightly used rotor with marks on the rivets if you still want to try)
Posted : 22/03/2009 10:47 pm
Just bend the non-bent tab a tiny bit, work fine for me. Certain hub/fork combos cause the rivets to touch the bottom of the post mount, but a file soon sorts that. Marzocchi Corsa had these issues, Reba and SID are fine.
Posted : 22/03/2009 11:05 pm
Just cut the tabs off.....
Posted : 22/03/2009 11:19 pm
So it looks ok then, with slight modification to the pads? Thanks all!
Posted : 23/03/2009 8:32 am
