I am having trouble with my juicy 7s in that the pad contact adjuster seems to have stopped working. Anyone have experience with these brakes and know what the problem is?
Thanks
not hard to take apart, if you take your time... easy to pull apart! and no easy answer for it? does it turn?
turns fine, just doesnt seem to make any difference in or out.
Well.... the turning moves the piston assembly and so it will move it, it is a worm gear against the cog that also screws the piston assembly in. it is physically moving the piston forward and backwards... I believe when bleeding you have to have the adjuster all the way out? can only "GUESS" that you would need to re-bleed with it all the way out, as if not setup right then i can see how it would turn but not affect the pads' position.
