Other than a German online bike shop for some cheap shimanos?
The rear is jammed on, lever firm - where to start?
Ta
Is it warmer than usual where you are? If so maybe too much fluid in there.
Any pads changed recently to non - OEMs?
Otherwise I think the German VAT man is going to be happy.
Mmmm it's melting in the hottest temperatures Glenmore has ever seen. I suspected it might be temp related - ill release some fluid and see if the fixes it. Ta
Happened to the Elixir on the back of my Stumpjumper on Thurs after it had sat in the car all day.
starting to hate Avid brakes. Anyway....I just removed the pads, released the caliper bleed screw and pushed the bleed block in. They are now working ok, but probably took a bit too much out so well be bleeding them soon, I reckon.
