Anyone know where I can get a piston kit for juicy threes? I can find them for 5/7 would these be compatible?
Just buy some hopes. Sorry.
Hi,
The juicy 3 ones are exactly the same as the 5/7. I used them for a service on my 3's.
Caliper pistons are the same, master cylinder piston is slightly different if I remember right.
I thought this was asking how to get out of Jury Service.
CRC do the 5/7 kit, . Not cheap though, at £37 IIRC. Pretty sure they d a new Juicy 3 complete for £50.
Hopes are shite. Sorry.
(But them floating rotors are nice). 😉
I think its just the caliper end, so kit for that is about a tenner, Master cylinder is at lever right?
Thanks all, even the comedians :-). Till i got this bike i was on cantilevers so the juicys are absolute cutting edge for me, Ive never even ridden a bike with hopes. And so far my experiences with juries has been from the other side 🙂
the avid 'service' is best described as throwing them in the bin, and getting some different brakes.
all brakes are about the same when they're working, it's just that avids don't seem to work for very long.
sorry.
You must have "special" brake tastes.
my mate usually finds the seal kit on the bay.
little bit of google trawling came up with this.
[url= http://www.dotbike.com/ProductsP8879.aspx?utm_source=google&utm_medium=base&utm_campaign=FGL ]Possible ? [/url]
backhander - Member
Hopes are shite. Sorry.You must have "special" brake tastes.
''Special Needs'' more like. 🙄
Forgot to mention-also get yourself a tub of silicone grease from a plumbers supliers, and smear it on the pistons and seals before assembly, you'll probably find it'll give a much better lever feel as the pistons will self adjust more easily.
Thanks all, ive ordered a new brake to keep me out there. And a bleed kit and caliper service kit for the learning experience. Ill get some of that silicon grease and i'll hopefully end up with a spare that works better than ever.
No offence taken from those who dont like them, its an honest opinion, and thats what I asked for. I spose i've got fairly low expectations of modern bike tech, I cant believe just how good even entry level bike stuff is these days.
