Joe Blow Mountain -...
[Closed] Joe Blow Mountain - for road
I need a new track pump, and was thinking about a Joe Blow Mountain, but I will also need to use it for my road bike. I usually run 70psi front, 75 psi rear, so in theory it should work, but will it work well or should I go for a normal, higher pressure one?
Posted : 21/03/2016 9:05 pm
My aged Joe Blow certainly inflated my road tyres just fine.
Posted : 21/03/2016 9:08 pm
Yeah will be OK, takes a bit of effort once you get to 60-65, even 80s doable (just).
Posted : 21/03/2016 9:21 pm
Yep. As dirtydog says, with a bit of bouncing up and down on the handle it'll go well past the range of the gauge with no apparent risk*
*I'm not guaranteeing that statement. Risk is still yours, but I've had it damn near back to 0.
Good for car tyres with the extra volume too.
Posted : 21/03/2016 9:26 pm
Aye that's the technique. ๐Ÿ˜€
Posted : 21/03/2016 9:28 pm
Go for the yellow one. It easily gets my road tyres up to 120psi.
Posted : 21/03/2016 9:39 pm
Why would you ever want to run road tyres above 80psi?
Posted : 21/03/2016 10:07 pm
No idea. I thought 100 - 120 was about normal for road.
Posted : 21/03/2016 10:19 pm
I have two of the yellow ones (inherited one). They work great on all my tyres. Even 650B ones.
They're pretty decent on my tubeless road tyres too.
Posted : 21/03/2016 10:59 pm
