I've just real...
[Closed] I've just realised why I am so slow...
My bike is knackered..
First race in 2 weeks, so thought I'd give the Anthem a quick once over. So in no particular order...
Brakes rubbing constantly, BB not a million miles from being seized solid, forks leaking oil (although to be fair they weren't until I tried to service them), and everytime I lift up the bike by the seat it 'clunks'..
So onto my questions..
The BB is a pressfit. Do I need any special tools, or can I do it at home?
Brakes, they are formulas. I've tried all the usual tricks and I can get them just about rub free, then I take the wheel off and they rub again. Any ideas?
And finally that clunking sound. No lateral movement in the rear triangle. Does it sound like a worn shock bushing?
If the bb needs a professional tool I'll probably take it to the LBS and get them to sort everything, but if not I quite fancy trying to save some cash and do it myself.
Posted : 18/05/2013 9:06 pm
You can do the BB with drifts and hammers but if, like me you can't put a shelf up straight, take it to an lbs with the proper tool.
Brakes probably need a proper clean / lube around the pistons and the klunk sounds very much like a shock bushing.
Posted : 18/05/2013 9:17 pm
Formula's love to rub, there's a recent thread somewhere
Posted : 18/05/2013 9:34 pm
the brakes use to work ok. What lube do I use on the pistons? Is it as simple as pushing them out as far as I dare, clean, then a drop of lube and then push back in?
Posted : 18/05/2013 9:51 pm
use brake fluid to lube and clean the pistons. apparently. not sure what type yours take though. use eye protection if its dot fluid
Posted : 18/05/2013 9:59 pm
Formula brakes have tiny pad to rotor distances. Check that your rotors are straight, and give the pistons a quick clean and lube with some brake fluid, it's probably DOT 4 or 5. You might as well give them a bleed at the same time to make sure that the pistons will retract all the way in.
The clunking when you lift it at the seat definitely sounds like a worn shock bushing. Order one of the bushing tools off ebay and replace them yourself, it's a pretty easy job.
Bottom bracket and fork sound like a job for a shop with the right tools and experience.
Posted : 19/05/2013 2:00 pm
Won't be DOT 5...DOT 4 or 5.1.
DOT 5 is not compatible with 4 or 5.1
Posted : 19/05/2013 2:57 pm
Get your shock bushing replaced with a non plastic one. Last longer. I once had a plastic one last two days of a stage race!
Posted : 19/05/2013 3:05 pm
