Issues with Handleb...
[Closed] Issues with Handlebar diameter at grips…anyone
I have an SQL carbon Bar and tried fitting a Twistloc remote but the grip wouldn’t tighten sufficiently to lock on. The bolt ended up shearing. I tried another Twistloc remote and it’s the same.
I used carbon gripping paste. I tried a thin insulation tape. I’m going to try a Smaller amount of tape.
Any other suggestions?
Thanks
Rich
Posted : 26/07/2021 8:23 am
Have you tried the remote on other bars to see if it's actually the bars?
Posted : 26/07/2021 9:34 am
Measure the bar with a digital vernier
I had a set of Wake brand chinese bars once that it felt like I had to overtighten brake levers on and grips wouldn't stick.
They measured just shy of 22mm at the grip area, should be 22.2mm. I glued the grips on.
If they don't measure 22.2mm then the bar is at fault. Otherwise it must be the remote clamp.
Posted : 26/07/2021 10:36 am
Hmm?
"The only complaint I have with the carbon SQlab bar is that the slick black-on-black finish is... well... slick. It makes tightening levers, dropper remotes, and grips so they are tight enough but not over-torqued a tricky exercise. The aluminum bar's slightly textured finish is perfect in this regard."
https://nsmb.com/articles/defying-convention-sqlab-12%C2%BA-and-16%C2%BA-sweep-bars/
Posted : 26/07/2021 10:40 am
0.2mm or 0.1mm all the way around is a tiny tiny amount. whats the diameter of the mount, just to be sure.
Posted : 26/07/2021 3:52 pm
Thanks for the comments! I don't have any other bars so I decided to run the unsightly DT Swiss 2 in 1 remote because I love the profile for the SQLabs handlebar. It pulls 11.5mm instead of 10mm but it seems to work okay. I will try again with another bar when I get back from holiday.
Posted : 26/07/2021 8:41 pm
Twistloc remotes are known for this. It's the problem not your bar.
Posted : 26/07/2021 8:47 pm
