Community
Is this the disc I ...
[Closed] Is this the disc I need? (upgrading Hope X2s)
As in post.
I have Tech X2s and am a little underwhelmed by the front braking (and want a little more bling from Father Christmas).
[url= http://www.chainreactioncycles.com/hope-mono-mini-m4-disc-brake-rotor/rp-prod80537 ]Will Hope Mono Mini-M4 discs fit[/url]?
Also, can anyone show me the adapter I need for a post mount plus 40mm on chainreactioncycles? I assume I'm being stupid, but can't see it anywhere.
I have 160mm discs at the moment. Should I get 200mm or 203mm? The forks are Fox 32s.
Very confused?
Thanks a lot,
Mike
Posted : 28/11/2013 10:50 am
Is this the adapter?
Thanks
http://www.chainreactioncycles.com/hope-mount-adaptor-front-post-to-post/rp-prod13728
Posted : 28/11/2013 10:57 am
Hope Mono Mini/M4 183mm floating rotor saw tooth is what you need + suitable Hope adaptor (either post/post or IS/post). Post/post in 183mm is the Hope H adaptor.
Or if you are heavy/fast/ride in the Alps etc go for the 203mm version.
Posted : 28/11/2013 11:12 am
EDIT: someone else beat me to it.
Does it [i]have[/i] to be the saw version?
I'm not heavy or fast but have weak finger/s (broken several times) so prefer 200mm.
Thanks
Posted : 28/11/2013 11:14 am
Yes it does need to be the saw version. Give Hope a call for the definitive answer if you're not sure.
Also if you decide to go for the 183mm option I have a spare H mount post/post in silver you can have cheap! Email in profile.
Posted : 28/11/2013 11:49 am
Thanks for the help.
I ordered the 203mm but thanks anyway old_mtb'er
Mike
Posted : 28/11/2013 2:37 pm
