Or would I have to get a ripple and rmove a ring?
Thanks
just use a 2x10 rings are the same really
The SLX cranks used to have a [url= http://www.chainreactioncycles.com/ro/en/shimano-slx-m665-double-chainset/rp-prod28019 ]2x version[/url], but I don't think they were any different chainline-wise.
Yep. They're also known as 2x10 cranks.
Otherwise, buy a triple and ditch the unwanted ring.
Cheers ๐
2x9 cranks. Have a set on my bike. Was 2x9 then 2x10 with same rings. Now 1x10
[url= http://www.chainreactioncycles.com/mobile/shimano-slx-m665-double-chainset/rp-prod28019 ]Double & bash. [/url]
But as above chainrings are interchangeable so just by the "modern" version
Any chance you're after a 40/28 XT M785 double in black with 175mm arms? I've got one brand new in box with a BB.
Possible.. What sort of money were you looking for?
I was more looking at alivio or deore as I've bought a new frame and will be transferring all my bits onto it, and muy current sram tripple is past it's best and I rarely use the small ring.
Will that bb fit this?
[url= https://www.bike-discount.de/en/buy/cube-analog-26-frame-grey-n-blue-233691?lang=en ]https://www.bike-discount.de/en/buy/cube-analog-26-frame-grey-n-blue-233691?lang=en[/url]
I had 2x9 with Middleburn XC Duo cranks in 2001, way before it was fashionable ๐
Haha, my bikes a bit of a frankenstien machine, hence why I grabbed that frame, it started life as a 3x8 carrera, straight steerer, has since been upgraded with carbon rims on hopes, Epixon fork, which I don't want to get rid of.
Frame is now battered visually but still structurally ok, and I find myself not using the smallest front ring on the tripple as the newer 9 speed cassette and shifters are good.
So I grabbed that frame linked above as it seems a bargain.
So I'm not sure what to do crank set wise, I don't really need a triple and it might save some weight getting a double. Current low end sram tripple is due for replacement anyway.
What was that only fools and horses joke?
My broom is 30 years old, it's had 7 new handles and 8 new brushes lol!
