is Sram XX compatib...
[Closed] is Sram XX compatible with Sram Red?
arternoon all,
have a flat bar road bike,was curious would the XX shifters work on a Sram Red rear mech?
im aware of the double tap rear shifters but would rather the XX if possible.
cheers
LLL
Posted : 27/03/2010 1:39 pm
Red and XX are completely interchangeable. I speak from experience.
I am running SRAM Red TT shifters with my XX mounted on Paul's thumbie mounts. Perfect match. XX is the only off-road groupset that will work with SRAM Red.
If you fancy something a bit different, you could try the same set up. The thumbies with TT shifters look a bit retro but they work really well.
Posted : 27/03/2010 1:46 pm
yeah i like that idea,very light weight.
but would it work the other way
atm you have: XX mech => red thumbies
would it work
red rear mech => XX shifters?
Posted : 27/03/2010 1:51 pm
Yep, they are completely interchangeable. Same cable pull.
Posted : 28/03/2010 5:43 pm
awsome cheers sola
Posted : 31/03/2010 1:49 pm
Yep, as above, be fine.
Posted : 31/03/2010 1:53 pm
Probably because XX is the only 10-speed mtb gruppo at the moment.....
Posted : 31/03/2010 1:56 pm
You are indeed a smart arse.
But the question was also about compatibility the other way. All of the SRAM road groupsets are 10 speed, but not all are compatible with XX.
Posted : 31/03/2010 3:25 pm
"You are indeed a smart arse. "
i lol'd
Posted : 31/03/2010 5:20 pm
You sure?
Posted : 31/03/2010 5:22 pm
