Is my square taper ...
[Closed] Is my square taper BB on its way out?
 Earl
Makes a clicking sound when riding. Off the bike it clicks when I lift and push down on a pedal.
Posted : 25/09/2009 9:42 pm
Probably, unless it's the pedal making the clicking noise.
Posted : 25/09/2009 9:46 pm
 Earl
Just gave the crank a tug and it clicks so prob not the pedals.
I assume they are throwaway and replace items? (its off a sum £500 bike). I think its a Truvativ so can i replace it with a UN54?
Much thanks
Posted : 25/09/2009 9:56 pm
Pedal bearing housing shot?
I've been running square tapers for a while,
they usually start wobbling a bit at first, can you feel any play though the BB axle?
Posted : 25/09/2009 9:58 pm
 Earl
No wobble - just a click. Hope it's not the frame!
Posted : 25/09/2009 10:13 pm
I think you'll find square taper BBs never wear out. It's only external BBs that do that. You have probably worn the rest of the bike out, but not the BB.
Posted : 25/09/2009 11:10 pm
If it just clicks with no wobble then ride louder :o)
Posted : 25/09/2009 11:16 pm
I wore one out, though it was 12+ yrs old and had a hard-ish life. Not difficult to or expensive to replace, the worst bit was getting it out of the frame, needed a 2 foot breaker bar to start it turning. If the cranks haven't been off for a while they might be hard to shift, especially if the extractor threads have gone. A three leg puller can be useful for that.
Putting it back - copper grease on the BB and square tapers, locktite on the crank bolts and do them up to the right torque. First time out take a box / socket spanner in case they come loose.
Posted : 25/09/2009 11:27 pm
Here we go again- to grease or not to grease square taper BBs....
Posted : 25/09/2009 11:42 pm
Is it the front mech cable catching on the crank arms as you do a revolution, I had an annoying clicking and thats what it turned out to be
Posted : 26/09/2009 12:31 pm
