is it worth swappin...
[Closed] is it worth swapping my forks ?
[#1279458]
ive got a set of 09 talas 140 forks that i run with a 9mm bolt thru qr now i never ever touch the travel adjust at all i was thinking of going for something with no travel adjust but with a 20mm bolt thru to try something different
Will i notice any real difference in stiffness and also if i keep mine am i likely to damage at all never swapping travel?
What would you recommend also in a 140 length i thought air pike maybe. Im around 13 stone and its for a bluepig.
Also what would i likely get for my forks. Very little used and mint ta
Posted : 31/01/2010 10:40 pm
how much would you like for them.
Posted : 31/01/2010 11:59 pm
as much as i can or a swap for some others if its worth doing thats why im asking im not sure if it would be a waste of time or not
Posted : 01/02/2010 9:37 am
 hora
At 13stone? Definitely not.
Posted : 01/02/2010 9:41 am
I'd expect you'd feel it but it's not going to change your life.
Posted : 01/02/2010 10:11 am
set of revelation 2010's would be good for you, prob wont weigh much more than your current forks if at all (3.85lbs i think) and will definitely be stiffer. you can space the 150mm ones down to 140 if needs be, maybe even shorter (though im not sure). i went without a travel adjust on my latest fork and dont miss it.
Posted : 01/02/2010 10:15 am
Got to disagree, I'm just under 13st and I find a big difference in stiffness between QR forks (especially 140mm ones) and forks with a 20mm axle.
But, to the OP, you might find you increase stiffness but decrease damping performance with a Pike or basic Revelation.
Maybe worth investigating the cost to swap the lowers on your Fox for the 15mm bolt-through ones, I think I was told that was possible.
Posted : 01/02/2010 10:16 am
 hora
mi©k although I own Pike and Lyriks I think the Fox Talas are smoother- less agricultural an option.
Plus my ****in almost new Pikes have ****ed and need repairing.
Posted : 01/02/2010 10:17 am
Do you honestly notice that much “lateral flex” or has magazine BS convinced you, you need 20mm?
What kind of riding are you actually doing? And does it demand a stiffer fork?
Posted : 01/02/2010 10:25 am
not really but sometimes there is some but i think im more concerned about them playing up if i leave them without swapping travel at all. also if ive a fair few quid tied up in them when i could get some as good forks for less money with no travel adjust
prob just keep em after looking at the above posts tho
thanks
Posted : 01/02/2010 2:42 pm
 hora
Its always nice to have travel adjust as you dont always ride in the same places.
Posted : 01/02/2010 2:46 pm
You can get a new set of fork lowers from Mojo and change yours to bolt-through. I think it's about £150, which is probably cheaper than selling your old forks and buying a new set.
Posted : 01/02/2010 2:57 pm
aye prob just keep em ta all
Posted : 01/02/2010 3:01 pm
