IS calliper to 74mm...
[Closed] IS calliper to 74mm PM fork - why doesn't the Hope adaptor work?
Trying to fit XTR 965 IS calliper to 74mm post mount fork. Have the Hope adaptor for this which includes +20mm disc size - and the calliper is too far out so the pad is only about 3mm onto the disc (180mm).
From a web search it looks as though I need A2Z adaptor AD-PMF74 - but why doesn't the Hope one work?
Posted : 12/01/2010 10:41 pm
Sounds like you may have a rear adaptor on the front
Posted : 12/01/2010 10:44 pm
I've got the A2Z one and You can have it for £7 posted. Red and worked fine to put my set of IS Martas on a Post Mount Bomber XC500 with a 180 xt rotor...
Posted : 12/01/2010 10:49 pm
 Mike
Sounds like you've It the wrong way round, as I'm running the same set up fine...fire up a pic If you can?
Posted : 12/01/2010 11:07 pm
 Mike
Or, just a thought...It's deffo a front IS caliper you have and not a rear?
Posted : 12/01/2010 11:09 pm
It's definitely a front adaptor. I don't think you can fit it upside down. It looks a bit as though I just needed IS to PM without the +20mm. I'll try and post a pic now.
mieszko - thanks for the offer - may take you up on it if that is what I need.
Posted : 12/01/2010 11:51 pm
This what it looks like:
Posted : 13/01/2010 12:04 am
 Mike
Now I see your problem...your forks are Magura Thors right? If so, they're spaced for a 7" rotor without any adaptors, rather than the usual 6" so you'll have to run a 200 or 8" rotor with your set up
The A2Z adaptor will do the same thing as the Hope one...
Posted : 13/01/2010 2:30 am
Yep, Thors. Thanks for confirming that - I was coming round to that conclusion. Cheers HTC.
Posted : 13/01/2010 9:37 am
I'm presently suffering the same problem trying to fit an 8" rotor to my Thors.
The bloody Hope adaptor clashes with the Hope M4 caliper!!
Posted : 25/01/2010 11:02 pm
