IS Caliper to Post ...
[Closed] IS Caliper to Post mount with 160mm disc can't be done, right?
IS caliper to Post mount fork: Trawling around I see adaptor for 180mm disc, but not 160mm, so guessing 160 it is not possible??
Posted : 22/03/2011 3:55 pm
 D0NK
I have a shimano adaptor which will run a 170mm and matching rotor if you need....
Posted : 22/03/2011 4:33 pm
What D0NK said.. although it seems to be a bit hit and miss as to whether it works, depending on what fork/caliper you are using (clearance issues).
Posted : 22/03/2011 4:39 pm
Thanks - mrcamel, thanks- interested, but may be limited by the fact my hubs take splined rotors though?
Posted : 22/03/2011 5:14 pm
mmmm, yes, you can do splined to 6 bolt adaptor but thats just somat else to buy!
Posted : 22/03/2011 5:22 pm
I've got a couple of splined to 6 bolt adaptors for sale, still boxed, if you are interested in going down that route
Posted : 22/03/2011 5:29 pm
Posted : 22/03/2011 5:32 pm
I may be missing something here...
Indeed. Caliper is IS; fork is PM.
Posted : 22/03/2011 5:34 pm
 bigG
You want one of [url= https://clee-cycles.co.uk/cc/catalog/product_info.php/cPath/21_123/products_id/989?osCsid=8nmp2rm7o3n5iv33teveoskte2 ]these[/url]
I used it to fit a Hope XC 180mm IS mount brake to a set of post mount Rock Shox. No need to go up in disc size or anything. Would work just fine for a set of 160mm
Posted : 22/03/2011 6:29 pm
Hey bigG !
I don't get it.
Is that 180mm adaptor + 160mm caliper + 160mm rotor ?
Posted : 24/05/2011 10:26 am
it's a post fork to 160mm IS adapter with a 160 caliper and disk I think?
Posted : 24/05/2011 10:28 am
